Do integrated and dedicated graphics work together?
Go to solution Solved by Godlygamer23,
1 minute ago, Nahidul said:
So how would you do that?
It is a function that is enabled in games that support the feature(and only DX12 games), which is called Multi-Adapter.
In DX12, that is technically possible, but by default, no.
1 minute ago, LordLeewee said:
low end amd stuff does
What?
4 minutes ago, Nahidul said:
Like if i had integrated graphics on my CPU or even an APU would it boost the graphical capabilities by working with a dedicated GPU like the 950?
For starters, that assumes your motherboard even allows the iGPU to be active when you have a dGPU, as some disable it automatically without you being able to do anything about it.
But assuming you can use both, the answer is no, unless you have software specifically coded for it (which, atm, I don't think any exists yet).
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
DX12.
thanks, so having an APU and a GPU working ttogether could increas fps if the CPU is not a bottleneck?
Yes, but only in DX12 games, and the games themselves must support the feature. It is not a default function that is there in all titles. It must be used by the developer.
DX12.
I know about DX12. But that's kind of a "programming language", not the apps themselves.
Your BIOS may allow you to use the iGPU for a monitor but gaming performance will rely on the CPU not the GPU.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
2 minutes ago, LordLeewee said:
http://www.amd.com/en-us/innovations/software-technologies/dual-graphics
r7's will crossfire with the r7 apu's. low end amd stuff.
Gna be using a Nvidia GTX 950 so doesnt really apply hear but thanks anyways
That has to be specifically enabled in the drivers, but you are correct.
It's software, and more specifically an API.
Sigh... matter of wording. We're both saying the same thing.
The game will still rely on the IGP for rendering.
Isn't that what I said?
Not exactly.
4 minutes ago, Godlygamer23 said:
Not exactly.
The iGPU is on the CPU is it not? Unless it's part of the chipset and motherboard.
It is not the CPU as a function though. CPUs as a function are terrible at rendering 3D graphics.
Ahh, thanks for clarifyiing.
