Simple move and click script
Go to solution Solved by CrazyMatt,
If you want to do just a teensy bit of programming, you can use AutoIt.
#include <AutoItConstants.au3>
Local $running = true
Do
 MouseClick($MOUSE_CLICK_LEFT, 25, 25)
 Sleep(3000)
 MouseClick($MOUSE_CLICK_LEFT, 50, 50)
 Sleep(1000)
Until $running = false
Hey all,
I want to make a script that will perform basically this action:
Click at (25,25) [x,y]
Wait 3000 ms
Click at (50,50)
Wait 1000 ms
Repeat
What would the best way to write this up?
I don't even know what to use to write it, but I will probably have to save it as a .exe
Thoughts?
CPU: Intel Core i7 8700k CPU Cooler: Corsair Hydro Series H100i Mobo:  Memory: G.Skill Ripjaws X 32GB 2133 Storage #1: 1TB 850 EVO SSD Storage #2: Western Digital Black 2TB Storage #3: Western Digital Green 4TB GPU: Gigabyte 980 Ti G1 Case: Mastercase5 PSU: EVGA 750 W G2 80+Gold Keyboard: Corsair K70 RGB Cherry MX Brown Mouse: Razer Deathadder Elite Monitor: LG 34UM94 Headset: Bose
Phone: Samsung Galaxy S9
https://linustechtips.com/topic/623515-simple-move-and-click-script/
use windows task scheduler?
I've never heard of that, and the documentation on the MSDN website is pretty terribly...
Have you used it before?
Do
 Sleep(3000)
 Sleep(1000)
Do
 Sleep(3000)
 Sleep(1000)
I literally just downloaded Autoit and was about to start playing with it
