Logitech G502 vs M65 Pro RGB:`final decision
asim1999
Which mouse do you think would be better overall (final decision)
17 members have voted
  1. 1. Which mouse do you think will be better for FPS gaming?
    • G502 Spectrum
      14
    • M65 Pro
      3
  2. 2. Which mouse do you think will betier for a palm grip and which one do you think is more comfortable
    • G502 Spectrum
      12
    • M65 Pro
      5
I am making my final decision by the end of the week and it should arrive by next Monday at the latest. Please answer the poll and these questions do I can make a final decision.
'And anyone who says that I should try them out I can't as there are a lack of retail stores for PC parts unlike the USA so pretty much all hardware purchases are online
Here are some questions that are not in the poll:
1) Do they share the same sensor?
2) I am planning to get a K70 or K95 in the future and I am worried that if I use CUE and Logitech gaming software on the same computer that they will interfere and slow down my PC significantly?
3) How much heavier is the G5-2 than the M65 or are they around the same weight when you use them?
4) Do you think RGB lighting is a gimmick and which mouse in your opinion has better lighting and more accurate colours?
5) is the sniper button on each mouse useful and does it help we have sniping in BF4 for example
Current Rig:   CPU: AMD 1950X @4Ghz. Cooler: Enermax Liqtech TR4 360. Motherboard:Asus Zenith Extreme. RAM: 8GB Crucial DDR4 3666. GPU: Reference GTX 970  SSD: 250GB Samsung 970 EVO.  HDD: Seagate Barracuda 7200.14 2TB. Case: Phanteks Enthoo Pro. PSU: Corsair RM1000X. OS: Windows 10 Pro UEFI mode  (installed on SSD)
Peripherals:  Display: Acer XB272 1080p 240Hz G Sync Keyboard: Corsair K95 RGB Brown Mouse: Logitech G502 RGB Headhet: Roccat XTD 5.1 analogue
Daily Devices:Sony Xperia XZ1 Compact and 128GB iPad Pro
G502 is poor for Palm grip. There's no where for the pinky to rest.
Bleigh!  Ever hear of AC series?
My vote goes to the G502, it's a fantastic mouse.
As for having more software, it won't impact your system that much. I've used both Corsair software (for my keyboard) and Logitech (for my mouse) in the past and it wasn't an issue. I've never used the M65, so I can't speak to that but the G502 is one of the best mice I've used. The sniper button I never found that useful, but it's more of a personal preference thing. Try it, see if you like it.
As for RGB, I'm a HUGE fan of RGB lighting. My current mouse in non-RGB and if it wasn't the best mouse I've ever used hands down I'd still be using my G502 just to match the rest of my setup. If aesthetics matters to you, going with all-RGB gear is a great choice because then you aren't limited to just one color scheme and can mix and match as you choose.
If its FPS, then neither, both are far too heavy to comfortably use to aim. Of course unless you are a high dpi/cpi player that does not play CSGO.
I am currently using a G502. And it has been great.
No complains.
If it is not broken, let's fix till it is.
