Annoying sound coming from a game
Windows10Home
I have a Razer Kraken Pro Neon, and I have them plugged in with the adapter into my case's front audio ports. Normally, theres no sound. But when I am playing Prison Architect, a extremely annoying high-pitched sound comes. I can't stop it. I tried saving, exiting, and loading the save up again, but no luck.
Please Help!
Windstriker 1.0
CPU: Intel Core i5 6600K
CPU Cooler: NZXT Kraken X61
Motherboard: ASUS Z170-A
Memory: Crucial BallistiX Sport LT DDR4 2400MHz 16gb (2x8GB)
GPU 1: XFX HD 7970 3GB Double Dissipation
GPU 2: Gigabyte HD 7970 3GB Windforce
SSD: HyperX Fury 120GB
HDD: Seagate Barracuda 1TB 7200RPM
Case: Fractal Design Define S
PSU: EVGA SuperNOVA 850 G2
Old Laptop
CPU: Intel Core i3 3110M
IGPU: Intel HD Graphics 4000
Memory: No-Name DDR3 4GB (1x4GB)
HDD: 443GB
I assume it isn't affected by volume changes?  It is probably some interference being fed into the sound system on your motherboard.
But it's only coming from that game
Windstriker 1.0
Old Laptop
HDD: 443GB
Have you ever checked frame rates when playing?  Are they insanely high by any chance?
Emm... 400FPS-600FPS...
Windstriker 1.0
Old Laptop
HDD: 443GB
try capping it at 60 with vsync and see if it goes away
How do I do it? There is non in-game
Windstriker 1.0
Old Laptop
HDD: 443GB
On an nvidia card you can set application specific settings in Nvidia Control Panel.  I guess for you it'd be in Catalyst Control Centre or whatever they're calling it these days?
I can't find any Vsync options
Windstriker 1.0
Old Laptop
HDD: 443GB
did you try clicking "more..." ?
nvm just spotted it: Wait for Vertical Refresh :)
This is more
Windstriker 1.0
Old Laptop
HDD: 443GB
This is more
sorry, see edit above:
To what setting
Windstriker 1.0
Old Laptop
HDD: 443GB
To what setting
On, or something like that :P
Now it On, and I have 350FPS
Windstriker 1.0
Old Laptop
HDD: 443GB
But still, the sound
Windstriker 1.0
Old Laptop
HDD: 443GB
That's not working then.  It should not exceed 60.
And if my theory is correct, this will fix the sound
Go to:  Gaming>select the game>Frame Rate Target Control... set it to like 60-90.
Doesn't work
Windstriker 1.0
Old Laptop
HDD: 443GB
4 minutes ago, Windows10Home said:
Doesn't work
The sound?  or the frame rate is still high?
Framerate and sound
Windstriker 1.0
Old Laptop
HDD: 443GB
Framerate and sound
Limit the framerate... then come back.  There is no point running that game at such a high FPS.  I assume your monitor runs at 60Hz?
You are overworking your GPU, it is most likely the cause of the noise.
I can't limit the frame rate! In-game there is no option! It doesn't work in Radeon Settings! (I have a 75Hz monitor)
Windstriker 1.0
Old Laptop
HDD: 443GB
Something is broken then because that control panel should let you pick any option and override whatever the game would naturally do.
