4 minutes ago, magnumkobra said:
If you want vr soo badly then get one , its not like its life threatening and the vr is ok at best but if you are robbing id recommend using the Banana Gun 3000, patent pending*.
there any way to get the gear vr to work with a s5?
https://linustechtips.com/topic/622182-samsung-gear-vr/#findComment-8024083
maybe but would require jury rigging and also it might not even let you use the games since it is not supported in the compatibility list. its not just the size difference but the way the lenses in the gear vr are positioned. it could probably give you a bad experience.
https://linustechtips.com/topic/622182-samsung-gear-vr/#findComment-8024123
