Is their anyway I can hook up my 360 to a window on my PC
Solved by chromeboy42,
You can't do what you are talking about, you could run a video capture device and then hav the output go to a window but then you are left with recordings of your gameplay every time you play which will take up a lot of space. Just connect the Xbox to one of your monitors and enjoy the fullscreen
3
srrrx ·
Posted in New Builds and Planning4 -
1
5
7
rayu ·
Posted in New Builds and Planning6
