Having copied HDD with factory settings (no date, just boot and OS) to my SSD, I now have the boot drive on my SSD.
however, now my both my Program Files and User folders and others on the SSD.
I wish to keep just the Boot on my SSD and move all the other folders onto a new HDD which I have installed which is completely clean (wiped).
https://linustechtips.com/topic/621398-hard-drive-to-ssd-problems/
afaik, the user folder cant be moved to a hdd, it has to be the boot drive. for program files, just change the install directory whenever you install anything from your ssd to the hdd
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
