what form factor do you want? i could list you a few cases, tho if you specifically want something mATX or ITX they might not be of any use to you.
Edited by RollinLower
typos and stuff
https://linustechtips.com/topic/621201-best-350-dollar-case/#findComment-8013360
1 minute ago, Chandres said:
ATX and up
well right now my personal favorite is the tempered glass edition of the Phanteks Enthoo Evolv ATX.
i believe it is around 200 bucks. damn amazing looking tho!
https://linustechtips.com/topic/621201-best-350-dollar-case/#findComment-8013376
The Enthoo Evolv cases are fantastic. There's also that EVGA one that was announced at Computex. Can't remember the name of that one. I personally don't see any reason to spend over $200 on a case. Is there something in particular you're looking for?
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/621201-best-350-dollar-case/#findComment-8013379
38 minutes ago, Chandres said:
Is it safe to work with the glass?
yes it is. just remove the panels and place them somewhere safe while you're working on the pc.
if you really want a silent case tho, i suggest you look into the newest BeQuiet! case:
https://linustechtips.com/topic/621201-best-350-dollar-case/#findComment-8013533
