Watercooling my first System
13 minutes ago, Rodniz said:---gone---
He got pretty damn good noctua fans
----gone
A bit of jealousy, lol jk
As for max radiators, he can fit a 280mm on top, a 140mm in front and a 120mm in the rear however, the 280mm with the 140mm will be enough for the CPU, GPU and the motherboard if you can get all three blocks. Try to get radiators with brass internals and blocks with copper internals to help combat issues that are associated with mixing metals in waterloops. A thickness of 35mm - 40mm will be good enough for the radiators.
Use a D5 pump. The best option would be to use one with a tube reservoir rather than a bay reservoir as bay reservoirs tend to make it a bit difficult to get the front panel off to clean.
Any CPU block with mounting support for socket 115x will work for the CPU bit i like/prefer XSPC's raystorm and EK's supremacy EVO.
I don't think you can get a full cover water block for the 390 because the GPUs are custom, EKWB surly doesn't make one but you can get a universal one, which is just a block on the GPU itself and you will have to figure out how you will be cooling the rest of the GPU on your own which is unwise.
Both Bitspower and EK make blocks for the motherboard in question.
A good place to shop for parts is from performancepcs .EKWB will ship to almost anywhere in the world too. You never said if you.your dad wants rigid/soft tubing, that is a factor that affects the fittings you buy/need. Regardless which ever tubing option you/your dad uses, buy extra tubing as this is your first time and you will be sure to spoil some runs and waste tubing...we have all done it. How do you/your dad plan to connect/control the fans? Yes you can use the motherboard but you can also use a fan splitter to run all the fans from one connection. What about fluid?...distilled water with silver coils/biocide is always best but there are pre-mixed fluids that already has this done for you which are good too.
