Just helped my friend build a PC on his mobo box over skype (build is exact same as mine), however it won't POST...
Please help! Thanks a lot :/
||| Drakon (Desktop Build) |||
|| CPU: 3800X || Cooler: Kraken X63 || Motherboard: B450 Aorus M || Memory: HyperX DDR4-3200MHz 16G ||
|| Storage: 512GB 970 Pro + 500GB 850 EVO + 250GB 850 EVO + 1TB HDD + 2TB HDD || Graphics Card: RX 5700 XT Red Devil || Case: Thermaltake Core V21 || PSU: XFX XTR 750W 80+Gold ||
https://linustechtips.com/topic/619982-new-build-wont-post-help/
PSU switch on?
https://linustechtips.com/topic/619982-new-build-wont-post-help/#findComment-8000904
2 minutes ago, DildorTheDecent said:
PSU switch on?
Good one...
In all seriousness, all the lights turn on and all that but no display.
https://linustechtips.com/topic/619982-new-build-wont-post-help/#findComment-8000911
4 minutes ago, GeorgeKellow said:
Check all cables, reseat gpu and cpu
Cables checked, RAM reseated in different slot, GPU reseated in different slot and then removed (using CPU graphics).
Reseating CPU ATM.
https://linustechtips.com/topic/619982-new-build-wont-post-help/#findComment-8000915
2 minutes ago, Aleksbgbg said:
Good one...
Does he have a GPU installed on that mobo? Make sure he's using the GPU's outputs and not the mobo's.
Blue Jay
CPU: Intel Core i7 6700k (OC'd 4.4GHz) Cooler: CM Hyper 212 Evo Mobo: MSI Z170A Gaming Pro Carbon GPU: EVGA GTX 950 SSC RAM: Crucial Ballistix Sport 8GB (1x8GB) SSD: Samsung 850 EVO 250 GB HDD: Seagate Barracuda 1TB Case: NZXT S340 Black/Blue PSU: Corsair CX430M
Other Stuff
Monitor: Acer H236HL BID Mouse: Logitech G502 Proteus Spectrum Keyboard: I don't even know Mouse Pad: SteelSeries QcK Headset: Turtle Beach X12
GitHub
https://linustechtips.com/topic/619982-new-build-wont-post-help/#findComment-8000918
Yes, we tried that but since it's not working we are using integrated for the time being, to make sure.
https://linustechtips.com/topic/619982-new-build-wont-post-help/#findComment-8000922
1 minute ago, Aleksbgbg said:
Good one...
For real though, PSU switch is easy to forget. I've two PSUs - one for PC and other for fans - and sometimes i wonder why i'm getting high idle and crashing in games.
Turns out PSU for fans wasn't on.
Listen for any beep codes from the internal speaker and use the manual to figure out that they are. beep codes and a debug LED (if present ) are great for error solving. Interesting to see that you've a DDR3 board and a 6600...
https://linustechtips.com/topic/619982-new-build-wont-post-help/#findComment-8000930
oh that part is different, he uses DDR4 and 6600k.
No internal speaker or debug LED present :/
PSU fan switch has 1 of 2 options, being: 1. Fan on during intensive use OR 2. Fan constantly on (so nothing wrong here)
https://linustechtips.com/topic/619982-new-build-wont-post-help/#findComment-8000943
2 minutes ago, PeloyGeek said:
might be dumb but i can't think of anything they haven't told you already, is the monitor on?
are the case connectors all plugged in right?
No case present.
Monitor on :/ I wished it was that simple
https://linustechtips.com/topic/619982-new-build-wont-post-help/#findComment-8000953
3 minutes ago, noob at PC said:
try only using one drive could work but im not sure
Already tried and currently using SSD only :/
https://linustechtips.com/topic/619982-new-build-wont-post-help/#findComment-8000955
1 minute ago, noob at PC said:
is the ram in the recommended dims
There is only 1 stick, we tried slot 1 and are now using slot 2.
Reccomended should be slot 1 right?
https://linustechtips.com/topic/619982-new-build-wont-post-help/#findComment-8000968
Sorry to get slightly off-topic but how do you have 2 PSUs in your computer?
https://linustechtips.com/topic/619982-new-build-wont-post-help/#findComment-8001364
There's one in my PC and one near my external radiator for fans. Mostly because it was sitting around.
https://linustechtips.com/topic/619982-new-build-wont-post-help/#findComment-8001375
If it wouldn't be too much trouble could you pm me a picture of that?  I'm having trouble picturing that sorry.  I figure this way I won't distract from this topic too much.
https://linustechtips.com/topic/619982-new-build-wont-post-help/#findComment-8001385
