Hello, I've been looking for a good place to talk to people about computer hardware and well, I've been watching LinusTechTips for awhile now and I checked out this forums.
I wanted to find out from other people, their opinions on this build. This is all selected by me and I have no idea if it works or not (although i have a good feeling it does).
Here is my Build: My Motherboard is a Gigabyte AM3+(GA-970A-DS3P).
                            My CPU is an AMD FX-8320E  Octa Core.
                            My GPU is a Gigabyte GeForce GTX 960 4GB DDR5 OC
                            My RAM is Crucial Ballistix 16 GB (8GB x 2)
                            My PSU is an EVGA 500W  B1 Bronze power supply
                            My Hard drive is a  WD 1TB
                            My Monitor is a ViewSonic VX2252MH
                            My Case is a Thermaltake Versa N21
Thanks for reading my post!
https://linustechtips.com/topic/619344-is-build-compatible/
should be
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
https://linustechtips.com/topic/619344-is-build-compatible/#findComment-7994056
3 minutes ago, Electronics Wizardy said:
It should work, but you can get better parts for the price.
First get a intel 6400 instead of a 8320. The 8320 is hot and slow and old.
Id get a rx 480 instead of a 960, faster and same price.
you make it seems like its bad cpu? sure its not as good as intel but its not crap. Unless you actaully had the cpu then you can call it shit all you want.
Also yeah get the 480 if you live in 'murica. if eu then the 480 isnt really worth the price
''Daddy CumTits 2.0'' (pc):
CPU - Intel i7 8700k
GPU - Asus Strix 1080 8gb
RAM - 2x8gb Corsair Vengance
MOBO - Asus Prime Z370-p
PSU - Corsair RM750x
https://linustechtips.com/topic/619344-is-build-compatible/#findComment-7994099
Please stop it. The CPU is old and has no upgrade path anything above a 970/290X will start to bottleneck.
https://linustechtips.com/topic/619344-is-build-compatible/#findComment-7994176
Have you tried it and seen how much it ''bottlenecks'' it?
https://linustechtips.com/topic/619344-is-build-compatible/#findComment-7994199
Yes, I've had the fx CPU when my friend gave me his first PC. After using it for 1 year I got rid of it. It was awful. The only possible way for it to work is to overclock. Which caused heat issues
https://linustechtips.com/topic/619344-is-build-compatible/#findComment-7994228
yeah well what one was it?
https://linustechtips.com/topic/619344-is-build-compatible/#findComment-7994229
FX-8350
EDIT: saw you RIG in your signature. What FPS do you get when playing? because you're diffidently getting a bottleneck
https://linustechtips.com/topic/619344-is-build-compatible/#findComment-7994233
FX-8350
I have it underclocked and i cant see anyreason that i would need to change it to anything else. If i can run almost everygame in 1080p ultra with well over 60fps whats the issue
https://linustechtips.com/topic/619344-is-build-compatible/#findComment-7994244
2 minutes ago, Abdul201588 said:
FX-8350
Havent played much since i got it but 120fps on doom in ultra and it dips to 80 if its really intensive
https://linustechtips.com/topic/619344-is-build-compatible/#findComment-7994253
What is your CPU and GPU utilisation?
https://linustechtips.com/topic/619344-is-build-compatible/#findComment-7994258
havent monitored it and cba since i dont have dual monitors so i woild have to tab out just to see it. Heaven benchmark wich i did had the cpu on under 50 and hitting lower when i did it couple mins ago and i had some other shait on at the same time
https://linustechtips.com/topic/619344-is-build-compatible/#findComment-7994270
That's the problem. If you search up videos, GPUs with intel CPUs perform better. So AMD CPUs are useless in high end gaming.
https://linustechtips.com/topic/619344-is-build-compatible/#findComment-7994278
During gaming.
https://linustechtips.com/topic/619344-is-build-compatible/#findComment-7994284
During gaming.
I hardly doubt that its any diffrent and more likely less than a benchmark designed to put your gpu to the test
https://linustechtips.com/topic/619344-is-build-compatible/#findComment-7994289
thanks for the suggestions! For the intel processor I would need to change the motherboard too right?
Also I thought the RX 480 hadn't been released yet so thank you for clarifying that. Also i see no problem with the AMD processor, it is cheaper, and runs faster at 3.2 GHz compared to the 6400 at 2.7 GHz but idk, I'm kinda new.
I don't really need an over the top gaming computer, just one that will run any game at 60+ fps at medium to high settings
https://linustechtips.com/topic/619344-is-build-compatible/#findComment-7994441
