Help! My PC Won't Boot!
Go to solution Solved by BbsMentos,
Try to press the clear CMOS button
Hi,
A few weeks ago, I've built a pc.
I've tried to overclock the CPU, didn't work, set back to clock speed, worked.
Everything worked fine until now.
My PC was running perfectly fine, but it suddenly shut down and didn't boot up anymore.
Well, its more like turning on the computer, worked for a few seconds, goes into windows, then shut down by itself. However, when I tried to turn it on again, it didn't go in to windows at all, tried to go into bios but it didn't work.
What should I do to fix this issue?
Also, the fans were running perfectly fine when I try to boot up my PC.
Specs:
CPU: i5 6600k
Mobo: Maximus Hero Viii
Cooler: Corsair H100i v2
Ram: Vengance 16GB Ram
PSU: RM850i
GPU: I don't have one yet
Thanks
Update:
When I switch my PSU on, the lights on my mobo turns on, however, when i press the start button on the mobo, none of the fans turn on, neither does the light on my cooler.
https://linustechtips.com/topic/619272-help-my-pc-wont-boot/
1 hour ago, Electro_XD said:
Hi,
Specs:
CPU: i5 6600k
PSU: RM850i
Thanks
Update:
Check if all the cables are plugged in correctly
  • CPU: AMD athlon  860k
  • Motherboard: Gigabyte F2A58M-HD2
  • RAM:2x4gb HyperX Fury
  • GPU: XFX R9 380 4gb
  • Case: NXZT S340
  • PSU: EVGA 650G
  • Display: BenQ GL2460HM
  • Cooling: Hyper 212 Evo
  • Keyboard: Corsair k60
  • Mouse: Steelseries Rival 300 (white
  • Sound Logitech g430
  • Operating System: Windows 10 64bit
https://linustechtips.com/topic/619272-help-my-pc-wont-boot/#findComment-7993144
wait im confused, is it posting?
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
https://linustechtips.com/topic/619272-help-my-pc-wont-boot/#findComment-7993152
Sorry for Bad English, Baguette here
STENDHAL: CPU: i5 6600K | MOBO: ASUS MAXIMUS VIII Ranger | GPU: MSI GTX 1070 GAMING X | RAM: 2x8GB Corsair Vengeance LPX 2400MHz | Case: CM HAF XB | Storage: Kingston UV400 240GB SSD + 750GB WD Blue | CPU Cooler: Hyper 212X | PSU: Corsair RM750X
https://linustechtips.com/topic/619272-help-my-pc-wont-boot/#findComment-7993155
Yes, after pressing the CMOS button.
Thank you, my system is now able to go into bios. However, I am currently in windows recovery mode, what should I press next? See advanced repair options or should I just restart my PC?
https://linustechtips.com/topic/619272-help-my-pc-wont-boot/#findComment-7993176
Try to restart
  • Case: NXZT S340
  • PSU: EVGA 650G
https://linustechtips.com/topic/619272-help-my-pc-wont-boot/#findComment-7993178
22 minutes ago, Electro_XD said:
Hi,
Specs:
CPU: i5 6600k
PSU: RM850i
Thanks
Update:
Reset CMOS
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/619272-help-my-pc-wont-boot/#findComment-7993240
