I just updated from 14.04 to 15.10. On 14.04 a GUI would come up, I would type my pass and login. But now it asks for my username which I don't know. Help me out.
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
https://linustechtips.com/topic/618446-ubuntu-help/
2 minutes ago, spartaman64 said:
you can type in root as the username and then type in your root password. then go into accounts and check your normal user
i dont know my root password
Build
https://linustechtips.com/topic/618446-ubuntu-help/#findComment-7984000
This right here.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/618446-ubuntu-help/#findComment-7984002
when you try to install a program does it prompts you for a password. thats the password you would use. it can be the same as your normal password
oooh ok thx, just getting to know linux here
Build
https://linustechtips.com/topic/618446-ubuntu-help/#findComment-7984018
So when you turn on your system to you see a gui or white text on black.
If you don't know your usename you can hold shift when booting and go to the recovery option and select then hit open a root command promt. Then type ls /home/
It will list your username there
Then try logging in and typing startx if you don't have a gui.
https://linustechtips.com/topic/618446-ubuntu-help/#findComment-7984036
