Hey, i'm going to be buying a new system soon and i was just looking for some advice on part selection.
any advice would be great. :D
case: NZXT Switch 810 Case Matte Black
motherboard: MSI Z77A-GD65 Motherboard
CPU: Intel Core i7 3770K
video card: XFX RADEON HD 7970 Double Dissipation Black Edition (already owned)
RAM: Kingston HyperX 16GB (4x4GB) DDR3 (already owned)
sound card: ASUS Xonar DGX (already owned)
storage: Seagate Barracuda 1TB (already owned)
Western Digital WD Green 1TB (already owned)
Intel 330 Series 180GB SSD (already owned)
PSU: Vantec 1000W 80 plus(already owned)
cooling:
Radiator: Black Ice SR1 240 Radiator
Black Ice SR1 360 Radiator
GPU watterblock: EK-FC7970 - Acetal + Nickel CSQ
CPU waterblock: EK-Supremacy - Acetal + Nickel
Reservoir: Frozen Q liquid fusion - 250mm (blue helix)
Tubing: PrimoChill PrimoFlex Pro LRT Tubing UV Blue 1/2ID 3/4OD
Coolants: MAYHEMS X1 CONCENTRATE CLEAR
Pump: Koolance PMP-450S 12/24V Water Pump
Pump mod kit: Bitspower D5/MCP655 Pump Mod Kit black
Bitspower D5 Mod Top V2 Acetal
Fittings: Bitspower Silver Shining Compression Fitting
Fans: Gelid wing 12 uv blue
Fan Grill: ModSmart 120mm Black Wire Formed Fan Gril
https://linustechtips.com/topic/618-need-advice-on-new-system/
Unless you are doing high end video editing, swap in a i5 3570k for the i7. Overclocks better, bit less heat and almost same performance for everything else. Also, 15ml of coolant? :) Hope thats a typo - I use typically over a litter on an initial fill. Also, go to local drugstore and get some basic distilled water. Use this to rinse everything out before you install.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/618-need-advice-on-new-system/#findComment-7577
thanks for advice :D oh yeah i forgot to change the coolant XD
https://linustechtips.com/topic/618-need-advice-on-new-system/#findComment-7607
Just out of curiosity, that frozenq reservoir
would it go well with a dyed coolant especially when the lighting and coolant color is the same?
I've seen people using distilled water and the reservoir really show strong and vibrant
https://linustechtips.com/topic/618-need-advice-on-new-system/#findComment-8332
You seem to have the money, upgrade that 7950 to a 7970.
Get a reference card if you want to waterblock it .
I actually have a 7970 i just stuffed up the post a fare bit :L also i have done my research and the XFX card i own uses a reference pcb
https://linustechtips.com/topic/618-need-advice-on-new-system/#findComment-8548
my bad i had my old list posted :L
https://linustechtips.com/topic/618-need-advice-on-new-system/#findComment-8565
change your case to a cm storm stryker and with some modding you can hold 2x 360mm rad
and change your mother board to a msi z77mpower
I would use that board if not for the color scheme :L pretty nice case i'll look into it, thanks :D
https://linustechtips.com/topic/618-need-advice-on-new-system/#findComment-8597
ee,s pretty good for me..
CPU: Intel i7 4790K @4.8GhZ  CPU Cooler: Be Quiet! Dark Rock Pro 2  Motherboard: Gigabyte Z97 UD3H  GPU: Asus ROG RX 480 8G OC Memory: 32GB Gskill Ares 2400Mhz  Storage: 2x Crucial M4 512GB SSD (raid0)  / 1TB Seagate FireCuda SSHD Case: Phanteks Enthoo Evolv ATX PSU: EVGA SuperNOVA P2 750W  Operating System: Windows 10 Enterprise LTSB (64 bit) Other: NZXT Hue+ LED Controller with 8 LED Strips for desk and PC lighting
https://linustechtips.com/topic/618-need-advice-on-new-system/#findComment-9030
  • 1 month later...
