Recently I acquired a super cheap Radeon HD7850, mostly because it was broken. I am trying my luck with it. So, here's the problem: there was thermal paste everywhere. Total horror fest. I've gotten rid of most of it, but now there are residual amounts of it left over.
Most of it are right at the corner of tiny resisters/capacitors on the top of the GPU creating a bridge, I don't have my test equipment here with me to test it at the moment. (Working on getting a photo up)
Any idea on how to get rid of it?
COMPUTER: Mobile Battlestation  |  CPU: INTEL I7-8700k |  Motherboard: Asus z370-i Strix Gaming  | GPU: EVGA GTX 1080 FTW ACX 3.0 | Cooler: Scythe Big Shuriken 2 Rev. b |  PSU: Corsair SF600 | HDD: Samsung 860 evo 1tb
Q-tip and isopropyl alcohol
Main PC:| CPU: Ryzen 5 2600 @ 4.1, MOBO: Asus B350 PRIME , RAM: LPX Vengance 2400 16gb kit, GPU: 980Ti Poseidon Platinum 6gb
                PSU: SilverStone Strider Gold Evolution 1200w , CASE: HAF 932  HDDs:240gb EX900 HP NVME 6TB (2x3 Seagate Barracuda)
                COOLING: ThermalTake Contac Silent 12
Laptop:MSI GL62 7RD  CPU: Core i5 7300HQ, RAM: 16GB 2400mhz, :GPU GTX 1050 2GB: HDDs: 256gb adata NVME + 1TB HDD
love all brands, will go for whats cheaper for my needs
I won't have access to isopropyl alcohol until Thursday. I've tried dry ones and that had gotten me rather close.
is it on the PCB or on the square that is the GPU die
AMD_Fiji_GPU_package_with_GPU_HBM_memory
this entire square is the GPU die
its fine to get thermal paste on the tiny chips on it
Just now, FirstArmada said:
Buy a new GPU cough sig cough
Nah, it's been working fine for me. Maybe once the 480 gets benchmarked a little more I'll think about it.
Back to the topic at hand.
Quote
It's on the 'small chips' as you would put it. As far as I can tell, the compound that was used was a conductive tim, meaning those chips are effectively shorts. While it probably won't kill it, it isn't healthy for it and it will force it to not run.
While this isn't the greatest photo, it does show the problem I am having.
how do you know it was conductive
nobody uses conductive thermal paste these days, especially not GPU manufacturers
Toothpick?
Honestly, if it's a conductive TIM and it's everywhere, you want to deep clean that thing.
Either wait for the alcohol, or just give the card a bath and scrub it with an extremely soft bristled brush. in circular patterns while it's submerged.
Using water is going to take a very long time though, as you'll have to let the card sit and discharge for a period of time before washing it, and it's going to take about a week to actually fully dry in rice.
So.... Probably go with the alcohol.
Well, GPU manufacturers also don't get thermal paste all over the GPU or use (what seemed to be) 2-part thermal paste and leave half of it unmixed on the side. I know I left these details out but still.
Just now, SageOfSpice said:
Toothpick?
Thank you. I don't think I'm going to give it a full bath, but Thursday I will be thoroughly cleaning it. I just wanted to get suggestions in the meantime.
this is what it manufacturer applied thermal paste looks like most of the time
and its perfectly fine
I'd like to point out how goopy and inconsistent this stuff is compared to yours. If you zoom in close to the edge, you can see it was also quite runny as well. The stuff on the edge and those lines are not from me removing it either. There was also a drop on a transistor/mosfet on the front and a drop on the back. Also looking at the tim that Sapphire used at the time it isn't consistent with what is here.
To me those seem like it was a careless person doing this.
Oh wow, that's disgusting. That looks more like toothpaste.
Luckily it wasn't, but at this point I think it almost would have been better if it was.
