AMD control panel shit keeps trying to update, windows keeps notifying me on each boot up, update won't run says this each time. Driving me crazy. http://prntscr.com/bm6pqv
Jesus is the way, the truth, and the life.
Please Quote me when replying.
CPU
 - Ryzen 7 5800X3D | RAM - 32GB DDR4 4000Mhz | MB - MSI B550 A-PRO | Boot - 2TB NVME 980 Evo Plus | GPU - EVGA FTW3 RTX 3090 24GB
https://linustechtips.com/topic/617653-help-im-going-bananas/
Did you try locating that in the file directory to see if the file is there or corrupted?
https://linustechtips.com/topic/617653-help-im-going-bananas/#findComment-7974270
No because I shouldn't be looking for the file I don't think... all I'm doing is clicking an update button and it says it can't find the file so Idk wtf to do. I could do a clean driver install but how does one do that without wrecking their PC?
CPU
https://linustechtips.com/topic/617653-help-im-going-bananas/#findComment-7974312
Oh yea and the GPU is an R7 370 4GB edition by sapphire, fairly new only about a month old.
CPU
https://linustechtips.com/topic/617653-help-im-going-bananas/#findComment-7974353
Are you trying to update drivers for an AMD video card.
or AMD apu/motherboard/chipset?
Photography / Finance / Gaming
https://linustechtips.com/topic/617653-help-im-going-bananas/#findComment-7974357
If the system reports the file isn't where it's looking for it then going to the file directory you might be able to fix or replace the file. You'll have to find it though.
https://linustechtips.com/topic/617653-help-im-going-bananas/#findComment-7974366
I was trying to update the control panel.
CPU
https://linustechtips.com/topic/617653-help-im-going-bananas/#findComment-7991424
