how to check pump speed in bios?
is there anyway to check the pump speed in bios as i dont think my cooler is working as my temperature in the bios hits 90 degrees :(
i have a asus sabertooth x99 motherboard
basically if the pump is plugged to the cpu fan header it will show the speed as "cpu fan"
Main PC:| CPU: Ryzen 5 2600 @ 4.1, MOBO: Asus B350 PRIME , RAM: LPX Vengance 2400 16gb kit, GPU: 980Ti Poseidon Platinum 6gb
                PSU: SilverStone Strider Gold Evolution 1200w , CASE: HAF 932  HDDs:240gb EX900 HP NVME 6TB (2x3 Seagate Barracuda)
                COOLING: ThermalTake Contac Silent 12
Laptop:MSI GL62 7RD  CPU: Core i5 7300HQ, RAM: 16GB 2400mhz, :GPU GTX 1050 2GB: HDDs: 256gb adata NVME + 1TB HDD
love all brands, will go for whats cheaper for my needs
its not showing up in the bios, but the fans are spinning, so shall i assume that the h110i is broke ?
uh no,  plug the pump intot he cpu fan heather
it is attached to the fan header
yh but is it the cpu fan header
CPU: Intel I5 4690K | GPU: Asus R9 280x | PSU: Evga 600w | RAM:8GB DDR3 | HDD: WD 1TB | HDD: WD 500GB | SSD: Sandisk 120GB
yeah defiantly, although the rpm might be set quite low that its not being detected, would that affect the temp of the cpu ?
