I'm looking to transplant Ikaros, our HTPC, into a much smaller case that can slide into a 4.75" tall opening without having to change graphics cards. I'm pretty sure we won't find any Micro ATX cases that can squeeze in there and accommodate a full-width, half-length PNY GTX 750 Ti, but a Mini ITX case with a PCI riser might work. I'm not opposed to changing out the motherboard if there's a case out there that can handle it. Lower cost is better. I'm also going to go by a local secondhand computer shop today and see what they've got--they haven't let me down yet, but I think this is an order a bit too tall for the stuff on their shelves.
TL;DR: Desperately seeking Micro ATX or Mini ITX case no more than 4.5" tall that can accommodate a full-width GPU (with the use of PCI risers if needed).
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/616760-45-tall-case/
https://linustechtips.com/topic/616760-45-tall-case/#findComment-7963697
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/616760-45-tall-case/#findComment-7963732
Are you going to want to use an optical drive with it?  In any case, you won't find such as case that uses a standard 5.25" optical drive, like in your parts list. At best you'd need a slim-line drive.
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/616760-45-tall-case/#findComment-7963766
Slim is fine. I'm not even entirely against using an external. Our local store is full of slimline drives.
https://linustechtips.com/topic/616760-45-tall-case/#findComment-7963772
