So recently my fathers computer that he have had for 10 years just isn't cutting it(who would have guessed). And I have built several pc myself, for myself. But I have only built high end gaming pc. And what my father needs is a very basic pc.
He will mainly use it for work, sorting documents and emails, and he works on a external desktop system. He also needs 2 screens for productivity. While I could just go out and buy him a prebuilt pc I would see if people have some suggestions for me, and what to look out for, what is worth spending extra money on, and what isn't.
I would prefer a small factor pc, but it is no way needed. So if anyone have any input on maybe a build I could make for him(with part list), or a prebuilt pc that is good(for him). And it would be a pro if it was somewhat silent. If there is room for a SSD for fast startups that would be nice too, but not needed. As my father do need some harddrive space to store documents and reports(several years worth).
And as I mentioned the last pc he had lasted for 10 years, so he isn't a heavy user.
I ask the community here for help because I don't have experience with building work pc or knowing what is important in terms of value vs cost. Hope I can get some good and useful feedback :)
https://linustechtips.com/topic/616253-work-pc/
depends on how much you are willing to spend... then you could throw in an ssd
GUITAR BUILD LOG FROM SCRATCH OUT OF APPLEWOOD
- Ryzen Build -
R5 3600 | MSI X470 Gaming Plus MAX | 16GB CL16 3200MHz Corsair LPX | Dark Rock 4
MSI 2060 Super Gaming X
1TB Intel 660p | 250GB Kingston A2000 | 1TB Seagate Barracuda | 2TB WD Blue
be quiet! Silent Base 601 | be quiet! Straight Power 550W CM
2x Dell UP2516D
- First System (Retired) -
Intel Xeon 1231v3 | 16GB Crucial Ballistix Sport Dual Channel | Gigabyte H97 D3H | Gigabyte GTX 970 Gaming G1 | 525 GB Crucial MX 300 | 1 TB + 2 TB Seagate HDD
be quiet! 500W Straight Power E10 CM | be quiet! Silent Base 800 with stock fans | be quiet! Dark Rock Advanced C1 | 2x Dell UP2516D
Reviews: be quiet! Silent Base 800 | MSI GTX 950 OC
https://linustechtips.com/topic/616253-work-pc/#findComment-7958497
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($110.99 @ SuperBiiz)
Motherboard: Gigabyte GA-B150M-D3H Micro ATX LGA1151 Motherboard  ($57.98 @ Newegg)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  ($31.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($92.00 @ B&H)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Case: Corsair Carbide Series 88R MicroATX Mid Tower Case  ($47.99 @ Micro Center)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply  ($52.99 @ SuperBiiz)
Total: $441.43
Generated by PCPartPicker 2016-06-25 04:56 EDT-0400
this is what I did a few months ago, office pc too. you might upgrade to the i5 if it is within your budget, it will give you a nice bump, but for office an i3 will do a good job too
- Ryzen Build -
2x Dell UP2516D
https://linustechtips.com/topic/616253-work-pc/#findComment-7958510
Motherboard: ASRock H110M-ITX/ac Mini ITX LGA1151 Motherboard  ($67.99 @ SuperBiiz)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory  ($26.99 @ SuperBiiz)
Storage: Mushkin ECO3 240GB 2.5" Solid State Drive  ($52.62 @ Amazon)
Case: Cooler Master Elite 130 Mini ITX Tower Case  ($34.99 @ Newegg)
Power Supply: SeaSonic 300W 80+ Bronze Certified ATX Power Supply  ($33.49 @ SuperBiiz)
Total: $374.56
Generated by PCPartPicker 2016-06-25 05:00 EDT-0400
https://linustechtips.com/topic/616253-work-pc/#findComment-7958513
Really good and interesting builds, really appreciate the feedback, I might decide, on going with the Corsair CX450M power supply instead, as I can't get a hold of the SeaSonic in my country. I might also be able to get a graphics card in there, if it is cheap, any suggestions for that?
https://linustechtips.com/topic/616253-work-pc/#findComment-7958533
nah, i don't think he'll really need a graphics card. the cx450m is good too, no worries.
https://linustechtips.com/topic/616253-work-pc/#findComment-7958537
http://pcpartpicker.com/list/3Vgbjc
I am not sure about rad support on the case. A little bit of M.2 game cant hurt. RX 460 is added and would be definitely powerful enough to power dual 4K.
Hardcore Hardware Whore | Check out my Blog for for Latest Tech News and more | Cricket Fan | Weapons Nut |
https://linustechtips.com/topic/616253-work-pc/#findComment-7958622
Intel integrated graphics will do fine.
https://linustechtips.com/topic/616253-work-pc/#findComment-7958710
