do intel CPU work best with AMD GPU
coz same peaple say its a problem for same peaple the PC keep crashing...
do i need to buy anather GPU an NVIDIA GPU?
csgo work well
call of duty black ops 3 work fine
BF3 and 4 is good and
gta 5 keep crashing when starting all the time
and today i try starwars bf and crashing the same thing
my old NVIDIA card works fine in all the games and no problem but its to old for a new games now days
i try everything in the forums nothing works.....
https://linustechtips.com/topic/615839-gpu-problem/
Intel CPUs will work with both Nvidia and AMD perfectly fine. Do you have your GPU overclocked? From person experience GTA 5 does not like having an Overclocked AMD GPU and crashes within 5 minutes of startup if it is OC'd. Star Wars Battlefront seems a little weird though as its a game that actually performs significantly better on AMD GPUs compared to Nvidia GPUs. That sounds more like a driver problems. Did you make sure to use DDU to uninstall all Nvidia drivers before installing your AMD drivers? AMD will not work properly if there are still traces of Nvidia drivers on your system and vice versa.
Just in case it probably wouldn't hurt to just try reinstalling all drivers after getting rid of them with DDU. Just make sure you only have AMD installed. Do not have anything Nvidia related on your system with the AMD card.
Gaming Desktop - AMD Ryzen 7 5800X, MSI MPG B550 Gaming Plus, 32GB Cosair Vengenace LP 3600mhz, EVGA RTX 3070 XC3 Ultra,  Sabrent Rocket 4 1TB NVME SSD, Crucial P3 4TB NVME SSD, 4TB Mass storage, EVGA 750W G2, NZXT H9 Flow
https://linustechtips.com/topic/615839-gpu-problem/#findComment-7954571
There are many many reasons for why something can be crashing beyond faulty hardware.
Excellent suggestion!
https://linustechtips.com/topic/615839-gpu-problem/#findComment-7954673
im sorry what do you ment by reinstalling all drivers? only the gpu have driver right?
im using MSI r9 390 so i use the MSI gaming app,,do you know the app?even when i was not using it,,it will still in OC mode and i switch to silent mode still the same keep crashing..even when im not using the app..u try ufterbuner but i dont know how to use it.....
https://linustechtips.com/topic/615839-gpu-problem/#findComment-7954723
2 minutes ago, eddy22m said:
im sorry what do you ment by all drivers?
Based on your description you are not overclocking. The OC mode from the card is factory overclock which is tested to be stable from MSI. As long as you dont manually change volt to your GPU you are not overclocking. All drivers means all the nVidia drivers you installed when you are using ur old nvidia GPU. You need to uninstall all of them and isntall the most up to date AMD drivers. Crashing most likly is becuz of driver issue.
https://linustechtips.com/topic/615839-gpu-problem/#findComment-7954731
u try the DDU app and after i go in to safe mode and the first thing i select AMD not Nvidia...the secand is to delete and restart and to delete and shutdown and the ather 1 i dont know..i try first delete and restart its still the same after i install the amd driver and the same thing when i select delete and shutdown...am i doing it wrong? or is they step by step on how to do it?do i need to uninstall the driver first than try DDU? or dont uninstall the driver just do DDU?
https://linustechtips.com/topic/615839-gpu-problem/#findComment-7954801
I'm not sure about SW:BF, but GTA V is very CPU intensive. It could be that your CPU is overheating and crashing.
What CPU do you have? What sort of CPU cooler are you using?
In any case, make sure your CPU cooler is free of dust and that the fan works properly. Of course, airflow through your case can also be a problem.
P.S. Anyone who tells you this old urban myth about AMDcpu/AMDgpu vs Intel/nVidia is someone who doesn't know what they're talking about and you can safely ignore almost anything else they tell you about computers. :)
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/615839-gpu-problem/#findComment-7954866
