so I need a GPS tracer for very cheap that can go anywhere and i can look and see where is is via phone or internet or something like that. I have a atnt phone with no service also.
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/615686-cheap-gps-solution/
1 minute ago, Newenthusiast said:
Sounds like someone is planning some stalking xD
Na, hitchhiker bot, i have one for that already it is too expansive to buy once more tho
https://linustechtips.com/topic/615686-cheap-gps-solution/#findComment-7952893
Buy a old phone. They have gpu and celluar and if you want you can log gps
https://linustechtips.com/topic/615686-cheap-gps-solution/#findComment-7952919
So would i have to get service? and is there a prepaid internet?
https://linustechtips.com/topic/615686-cheap-gps-solution/#findComment-7952924
Most phones comes with a built in gps, you just need to get an app that can use it like Navmii GPS World (Navfree) or something.
Build
Mobo: MSI B550 MAG Tomahawk  ||||| Ram: 32 GB GSkill Trident Z RGB ||||| CPU: Ryzen 5800X ||||| GPU: ASUS RTX 3080 TUF OC ||||| Mouse: Logitech G502 ||||| Headset: Sony WH1000XM3 ||||| Keyboard: Logitech G810 Orion Spectrum ||||| Monitors: Acer XG270HU & LG UltraGear 34GP83A-B ||||| AudioStuff: ONKYO DAC HA200 / Audio Techinca ath-ad900x / MXL TEMPO KR USB Condenser Microphone ||||| Storage: 4 TB WD Black --- 2 TB WD Red --- Toshiba 258 GB M.2  ||||| Custom Loop -  Radiators: 3x360 Rad ||||| Case: LianLi O11d XL Black ||||| PSU: Seasonic X series GOLD 1250w
Laptop: Dell XPS 15 9570 4k With a Logitech MX Master
https://linustechtips.com/topic/615686-cheap-gps-solution/#findComment-7952939
I need wifi right?
https://linustechtips.com/topic/615686-cheap-gps-solution/#findComment-7952944
ok
https://linustechtips.com/topic/615686-cheap-gps-solution/#findComment-7952951
2 minutes ago, Pcinacan said:
I need wifi right?
To download the app, yes. But it should work offline, I use it all the time when I go to the states and I never bother getting a roaming plan.
Build
https://linustechtips.com/topic/615686-cheap-gps-solution/#findComment-7952952
oh ok cool
https://linustechtips.com/topic/615686-cheap-gps-solution/#findComment-7952956
