Hello,
I'm close to finishing a store ready product but it does need a power button (connected to a micro-atx board). I was looking for power switches but every store had different names, codes and labels for their products. And when I asked them what they mean with the written specs they didn't know it either.
So whats the difference between all the switches? Like 4, 5 and 6 pins and what kind of connection to the mobo they need, the LED in the switch itself (how do I know it stays on or off when the pc is off but still has power). And how do I recognize a momentory switch against... uhm... a not momentory switch. And how do I recognive the postive and negative pole. And finally, I think I saw somewhere a "3-pin H.D.D. LED" mobo connection, so when its a 5-pin switch, does that mean one of them is ground?
And if you have some time left: I'm looking for a 'normal blue' or a white colored (form of a circle) momentory switch. I don't think I want it be HDD connected because of the annoying flickering; but it does need to be off when to PC is off.
Thank you for your time and effort! It's really appreciated!
https://linustechtips.com/topic/615618-power-switch-wiring-explaination/
this is what you need
http://www.frozencpu.com/cat/l2/g52/c341/list/p1/Switches-22mm_Vandal_Resistant_Switches.html
they dont sell them at most hardware stores
it should say in the specs if its momentary or not
switches do not have + and -, only LEDs do
and it will say either in the instructions or on the switch
usually engraved in the plastic
there is no such thing as a 3 pin hdd led
the led in the switch gets wired to 12v from your PSU
it turns off when the PC shuts off
27 minutes ago, Arend-009 said:
Hello,
Kind regards,
Arend Galenkamp
what where the written specs?  we could probably figure them out, most switches will show a voltage, or current raiting on them or show
SPST  (whihc it Single Pole Single Throw) Has 1 pole (the number of circuits it can control Where throw is how many positions it could have
SPDTHas one Circuit but has 3 pins on common and will make or break either other position
DPDT has 2 circuits and will make or break the other connection
Also they have momentary (a single push will short the switch briefly)
and Latching pushing it will hold until released
For a computer you want momentary SPST (you could use a DPST if you wanted to and hook the other one up to something to do something,
  ie, hook one end up to the pc, and the other to a doorbell so you know if someone turned it on,  or hook it up to an Alarm to know someone turned it on etc.
  Yes I know they are dumb expamples but could be done.
I have used this before and put it on a desk just to get people to be WTF
http://www.relcross.co.uk/product/121/KS_Series_-_Key_Switch/
Hope this helps
  • 2 weeks later...
Hey guys,
First off, sorry for the late reply, I thought the forum would e-mail me when I got an answer. Anyway, thanks a lot for the explaination of both of you, it helped me a lot! Now I know a lot more about the switches as wel as electricity. I'll post a link to the finished product here when it's finished.
