Imagery Help!
Go to solution Solved by Murasaki,
3 minutes ago, iLoveLogitech said:
I've done some searching and one tutorial seems to be 7 years old, which doesnt really work, unless if I missed a step, other tutorials show vertical rotation
Click on the layer, open the transform properties, click the clock next to rotation, move the timeline a second or so later, set the rotation to 1x, 0 degrees.
1 minute ago, ModuleLFS said:
at work so can't really show you anything, you can always search on YouTube for tutorials, there are plenty.
https://linustechtips.com/topic/615259-imagery-help/#findComment-7947117
https://linustechtips.com/topic/615259-imagery-help/#findComment-7947145
