Hello,
Ive gone through every connection everything seems snug,
I have only a 950 m.2 drive store device installed.
I get this red led behind the nand drive lighting up but thats the only indication somethings wrong but not sure what, any tips?
Could it be my ram not compatible or listed in the manual?
Mobo: asus z170-ar
Ram: cmk16gx4m2b3000c15
In the manual only has; cmk16gx4m4b3000c15
Could this really be why no post?
CPU: AMD 5800X3D / Cooler: Noctua NH-U9S / Motherboard: MSI MPG B550 / GPU: EVGA GTX1070 SC / RAM 64GB G.Skill TridentZ RGB / SSD: WD Black NVME / HDD 1: ADATA XPG SX9200 Pro / HDD 2: Lexus NS100 / PSU: CORSAIR RM850 / Case: Corsair 5000D
https://linustechtips.com/topic/613232-first-boot-no-post-help/
When I first power on the red dram led goes on then switches off, then the vga led, then the red led under the nand drive :*(
https://linustechtips.com/topic/613232-first-boot-no-post-help/#findComment-7924558
Where is the display cord plugged into?
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
https://linustechtips.com/topic/613232-first-boot-no-post-help/#findComment-7924568
is the 8 pin CPU power connector plugged in? Can't really see that port in the photo.
Gaming Desktop - AMD Ryzen 7 5800X, MSI MPG B550 Gaming Plus, 32GB Cosair Vengenace LP 3600mhz, EVGA RTX 3070 XC3 Ultra,  Sabrent Rocket 4 1TB NVME SSD, Crucial P3 4TB NVME SSD, 4TB Mass storage, EVGA 750W G2, NZXT H9 Flow
https://linustechtips.com/topic/613232-first-boot-no-post-help/#findComment-7924573
If I'm correct that's the boot device led, might need to connect a regular drive via sata to update bios and set things up
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/613232-first-boot-no-post-help/#findComment-7924574
Thanks guys also sorry I rebooted and waited a bit longer and posted into the uefi bios. I didnt really do anything
No more red leds apart from the few first moments from powering on the system.
I have it plugged into dvi and cpu power is plugged in, I plan to install hard drives after I get w10 on this nand drive
Ill probably run into another false alarm soon lol.
https://linustechtips.com/topic/613232-first-boot-no-post-help/#findComment-7924598
Take the GPU out, then reconnect It, plug the power connectors back In...
If not plug the GPU out and just use iGPU. See if that makes a difference.
ABOUT ME: Hello, I'm a 15-year-old PC enthusiast. I love helping people with their problems and learning about the hardware of a PC.
DREAM JOBS: Computer Technician, I.T Consultant or a Computer Hardware Engineer.
NEXT BUILD: http://nz.pcpartpicker.com/list/rDXLJV (NOT COMPLETED)
BE NICE TO ONE ANOTHER AND HAVE SOME FUN!
https://linustechtips.com/topic/613232-first-boot-no-post-help/#findComment-7924617
Glad you got it.
https://linustechtips.com/topic/613232-first-boot-no-post-help/#findComment-7924755
23 minutes ago, BunnyLab said:
Glad you got it.
Cheers.
Do things look okay guys the 0 rpm fan on the h100 is making me nervous but all fans are on inside the case?
https://linustechtips.com/topic/613232-first-boot-no-post-help/#findComment-7924844
