5 minutes ago, MDH said:
I want to use low voltage ram with my system but my motherboard doesn't specifically say it supports it, will this be a problem or will I have incompatibility issues?
It should work regardless, the other way around may not work though(ex. ddr3l in ddr3)
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/612598-low-voltage-ram/#findComment-7917755
5 minutes ago, typographie said:
Need some specifics. What RAM, and what motherboard/CPU?
Specifics not set in stone, just generally asking will 1.35V work fine in most systems. But specifically, I am thinking about using an ASRock H61M-HVS motherboard with a i5 3570K, don't know the ram specs, just 1.35V.
https://linustechtips.com/topic/612598-low-voltage-ram/#findComment-7917760
Don't worry too much. Low voltage ram will work just fine.
https://linustechtips.com/topic/612598-low-voltage-ram/#findComment-7917772
3 minutes ago, MDH said:
Ah, cool. So there are motherboard built for DDR3L?
Certain skylake boards have ddr3l only since the higher voltage can kill the memory controller, but your h61 board will be fine.
https://linustechtips.com/topic/612598-low-voltage-ram/#findComment-7917794
