Hi guys,
I'm trying to join a LAN world I am running using the Minecraft Server JAR. I have set it up properly since I can connect on my own desktop.
However it doesn't connect on my laptop and says this....
Any way to fix this?
The laptop has an Ethernet cable plugged in, just like the host computer and they are both on the same network.
Thanks.
Judge a product on its own merits AND the company that made it.
How to setup MSI Afterburner OSD | How to make your AMD Radeon GPU more efficient with Radeon Chill | (Probably) Why LMG Merch shipping to the EU is expensive
Oneplus 6 (Early 2023 to present) | HP Envy 15" x360 R7 5700U (Mid 2021 to present) | Steam Deck (Late 2022 to present)
Mid 2023 AlTech Desktop Refresh - AMD R7 5800X (Mid 2023), XFX Radeon RX 6700XT MBA (Mid 2021), MSI X370 Gaming Pro Carbon (Early 2018), 32GB DDR4-3200 (16GB x2) (Mid 2022
Noctua NH-D15 (Early 2021), Corsair MP510 1.92TB NVMe SSD (Mid 2020), beQuiet Pure Wings 2 140mm x2 & 120mm x1 (Mid 2023),
https://linustechtips.com/topic/612492-minecraft-java-exception-help/
7 minutes ago, AluminiumTech said:
Hi guys,
Thanks.
Is the Minecraft server allowed through the firewall?
2 minutes ago, gFrenken97 said:
did you port forward?
It's only inside a local network. I don't need to port forward.
And also, I got a new error.
Yeah and I am getting a new error now for some reason.
1 minute ago, gFrenken97 said:
if it's hosted at home, the ip is "localhost"
I put the IP address as my internal IPv4 address of the computer.
For my host computer it's 10.0.1.24 on port 5000 (idk I just randomly decided upon a number)
Well I don't think you can use any port. You have to use the correct port. Which is 25565
Lol. Everybody says the default  port is stupid and I've used other ports before with no problem. Like E.g. Port 10000 always worked for me except this time I also tried that and it didn't work.
That's only if you're going to open the server to the public. Doing it locally on a LAN wouldn't do any harm.
4 minutes ago, No said:
make sure you use the same version of minecraft as well
I know. Using the latest new 1.10 update xD. With polar bears and stuff.
AND somehow it works after restarting my laptop.......
Miraculously.
IDK what happened BUT it worked.......
2 minutes ago, No said:
i know wht happened but im not telling u
Come on, IDK what triggered it to not work.
