Do not use that GPU tweak or whatever it is called. It caused me a lot of problems like restarts etc etc. just use radeon settings or gpu z and dont use the presets that are included in that gpu tweak.
AMD Phenom II X6 1055T |Asus M4A88T-M |A-DATA 8 GB(4x2) @1333|Asus R7 360 2G OC|Asus TA-M1|Hitachi 7211 1TB|Fortron 460W|Windows 10 pro 64
https://linustechtips.com/topic/612232-problems-with-gpu/page/2/#findComment-7914198
Hi, Now Im having a problem that my GPU is bottlenecking. It didnt do this before:
http://i.imgur.com/IPnDZze.gifv
https://linustechtips.com/topic/612232-problems-with-gpu/page/2/#findComment-7917323
That problem with stuck GPU clocks is cause by the AMD driver try different versions from AMD website including older ones and see which works best for youl.
16.5.1 does work best for me.
https://linustechtips.com/topic/612232-problems-with-gpu/page/2/#findComment-7956634
do you play with chrome open?, on some games that used to cause my clocks to saty lower than their max
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
https://linustechtips.com/topic/612232-problems-with-gpu/page/2/#findComment-7956646
Yes i guess that is after watching a video in chrome it will stuck your clocks to 2D mode.
I am running 16.5.1 driver right now and it works well a few older had that same problem.
Use AMD CCC to clean your existing driver first or ever find Guru3D display driver unistaller then try a few versions if all does not work go back for 15.7.1 i guess.
Maybe somebody who has the same card as yours will respond with working version ?
https://linustechtips.com/topic/612232-problems-with-gpu/page/2/#findComment-7956714
