Will a hyper 212 evo fit in a rosewill fbm-02
Solved by LogicalDrm,
Doesn't fit according to https://uk.pcpartpicker.com/b/hZm8TW
However other sources say it might with really tight fit. If you have option to return cooler or buy it later, you can measure distance from socket to sidepanel once you have the case.
Featured Topics
digitalscream ·
Posted in Graphics Cards0 -
1
2
Xyd9 ·
Posted in Linux, macOS and Everything Not-Windows3 -
2
3
5
EzioWar ·
Posted in CPUs, Motherboards, and Memory9
