WiFi problems: Packet loss, slow internet, location and time based?
A decent 5Ghz router should fix it.
If every device you have also supports that and there aren't too many walls in the way you should be fine.
The problem is that every router is comparable to a shouting person.
The more there are, the more difficult it is to talk to something (your devices).
Also it's sometimes fine because the other routers don't have any data to transfer so they are quiet.
But when everyone is home and using their wifi, it's just a complete mess of everyone just yelling at each other.
Result, end devices can't understand a thing what's been send so it's a complete mess.
Of course the further you are the worse it gets.
The processing power doesn't matter, it's how strong the antenna is. It's comparable to how loud your router can yell.
