Best air cooler for skylake
Marius5013
Hi everyone im building a new computer and i need the best air cooler i can get for my Intel Core i7-6700K Skylake ive heard that the Noctua NH-D15 is good but what about the Noctua NH-D15S any difference?
The NH-D15S is offset to make room on the motherboard and only has one fan instead of two. Meaning that the NH-D15 is going to edge it out in most scenarios.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
NH-D15s performs exactly the same as the NH-D15. The only difference is that the NH-D15s has fixed compatibility with the first PCI-e slot on the motherboard because on some motherboard you cant install anything into the first PCI-e slot as the NH-D15 is so wide that it blocks it.
Other good options are Cryorig R1 Ultimate or Be Quiet! Dark Rock Pro 3.
And im going to overclock my cpu and gpu atm i considering the bequiet cooler but is it any good if im going to overclock?
It's an excellent cooler. It's not quite NH-D15 levels but the difference is too small to really matter.
Another thing im using the Fractal design define r5 case and i need fans for the case i want silent once but they need to perform well i just dont know which fans to choose any suggestions?
If you want a true silent build, get the nh-d15 and then get 3 of the exact same fans for inflow and outflow.
What you do next is buy a 6 way splitter for the fans and controll them all with the cpu fan header.
Wala, now you can run your fans at 300rpm when idling and ramp it up a tiny bit with a fan curve of your choosing.
Im new to building computers so do you know if the nh-d15 will fit into a Fracral design define R5
And can you guys tell me if this cpu cooler would work well and what fans that would be good for my pc
And do you guys think this PSU / Power supply would work well with everything
Computer Case - Fractal Design Define R5 Black
Power Supply - EVGA GQ 850W Hybrid Modular 80+ PSU
Motherboard - ASUS Z170 PRO GAMING, Socket 1151
Computer Memory - Crucial DDR4 Ballistix Sport16GB
CPU - Intel Core i7-6700K Skylake
CPU Cooler - Be Quiet Dark Rock Pro 3
Graphics Card - MSI GeForce GTX 1070 Gaming X
Hard Disc Drive  - Seagate Barracuda HD 1TB
Hard Disc Drive SSD - HyperX Fury 120GB
Fans - No fans atm
Edited by Marius5013
Computer Case - Fractal Design Define R5 Black ---- Check
Motherboard - ASUS Z170 PRO GAMING, Socket 1151 ---- Check
Computer Memory - Crucial DDR4 Ballistix Sport16GB ---- Check
CPU - Intel Core i7-6700K Skylake ---- Check
CPU Cooler - Be Quiet Dark Rock Pro 3 ---- Check
Graphics Card - MSI GeForce GTX 1070 Gaming X ---- Check
Hard Disc Drive  - Seagate Barracuda HD 1TB ---- Check
Hard Disc Drive SSD - HyperX Fury 120GB ---- Check
Fans - No fans atm
Yes it will fit easily in the r5, i use one with th nh-d15 so don't worry.
the only thing you might need to watch out for is getting a good gpu that doesn't make noise. Either get a msi twin frozer or if you are more couragoues, mod any gpu with a mk-26 or arctic accelero.
Oh also get a psu that turns its fan off when under light load.
I know this is my setup
Power Supply - EVGA GQ 750W Hybrid Modular 80+ PSU
Fans - Fractal Design Dynamic GP-14 x3
