Best Air Cooler under 140mm (Height)
8-Bit Ninja
So my brother wants a new cooler to replace his stock amd 7870k (I think) cooler. Preferably under £30ish though i'm sure he'd go up to £40 if there was a large difference. I've agreed to overclock his apu for him, so honestly cooling over noise.
What case do you have?
Cryorig H5 Ultimate or the H7
The H5 is 36.49 pounds and the H7 is 27.49 pounds
Let's agree to disagree
from were?
both are £40 on amazon
Both are too tall.
The Core 1100 allows for 148mm of clearance.
Katana 4 is good: https://www.amazon.co.uk/Scythe-SCKTN-4000-Katana-CPU-cooler/dp/B007Q4XSDE/ref=sr_1_9?ie=UTF8&qid=1465577970&sr=8-9&keywords=scythe+heatsink
15 minutes ago, 8-Bit Ninja said:
from were?
https://www.alternate.co.uk/Hardware-Components-Cooling-CPU-Coolers/html/listings/11898?tk=7&lk=4549&page=3#Cryorig
I always buy my stuff at alternate belgium bought all my pc needs from there since 2009
And ive always had great customer support too
Edited by MrTiC
I would go for the Noctua L9i. It's only 37mm tall.
  • AMD Athlon X4 760K CPU   |   MSI FM2+ ATX A88X-G45 Motherboard   |   8GB 1600MHz RAM   |   MSI GTX 760 GPU (Reference)
  • Thermaltake Versa H22 Case   |   1TB Seagate, 0.5TB Hitachi (7200RPM)   |   ArcticRed+ 700WStock    |   Windows 8.1
2 minutes ago, WoodenMarker said:
The H7 is  123 x 145 x 98 mm so it should work, its tight but still ...
I would have sugest the C1 too but its over budget 48.49 pounds
Thanks for the correction. I was still thinking of 140mm for some reason.
Two nice LP coolers are the Prolimatech Samuel 17 and the Silverstone AR06.  For overclocking of the two I'd suggest the Samuel 17 with a good 140 mm fan that has 120 mm mounting holes.
It really does vary.  e.g. The Zalman T1 Plus states that it accepts coolers up to 140 mm in height.  It will not fit an 212 EVO, but an H7 will just fit.
