http://pcpartpicker.com/list/Nn3ZLD
Need some help with this build that I will be building in a few weeks. I am willing to go with an APU to get rid of the cost of the GPU. This machine will not be a gaming computer but will just be a basic computer. Thanks for the help.
https://linustechtips.com/topic/609111-need-some-help-with-new-build/
So if you don't plan on doing any gaming then yeah just get rid of the 750 ti. Also $100 on a cpu for basic computing is a little overkill. I would look for a cheaper one around $50 your total cost would be around $250.
Ariana Grande's Leaked Nudes!!!111!11!
Ayyyyyy
Gaming Rig:     CPU:  i5-4690k  Cooler:  H80i  Mobo:  MSI z97 PC MATE  RAM:  16gb Fury White  Storage:  1TB WD + 120gb Fury SSD  GPU:  GTX 970  Case:  NZXT S340  PSU:  NEX 650W  Keyboard:  K65 RGB  Mouse:  Mionix Naos 7000  Headphones:  ATH-M50x  Monitor:  2x VN248h-P + 1x MG248q  Setup Photo:  (To come)
you will want some bulk storage for that PC so just throw in a 2 or 3 TB HDD
Builds:
Well I meant it would not be built for hardcore games. So with this information I could go with an APU.
1 minute ago, g12601 said:
I doubt he will need more than 240GB, I would rather have him get relatively small and fast storage than big and slow storage.
you WILL need more then 240gb, trust me. pictuers and stuff take up loads of space. it will ofc be less with no games but after a while stuff adds up
Builds:
You'll probably be fine with just this for light gaming.
CPU: AMD A10-7860k 3.6GHz Quad-Core Processor  ($104.99 @ SuperBiiz)
Motherboard: ASRock A88M-G/3.1 Micro ATX FM2+ Motherboard  ($50.99 @ Newegg)
Memory: PNY Anarchy 8GB (2 x 4GB) DDR3-2133 Memory  ($31.99 @ Amazon)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($57.70 @ NCIX US)
Case: Rosewill FBM-01 MicroATX Mini Tower Case  (Purchased For $0.00)
Power Supply: Antec 550W 80+ Certified ATX Power Supply  ($59.99)
Total: $305.66
Generated by PCPartPicker 2016-06-10 11:29 EDT-0400
4 minutes ago, Finnskii said:
An SSD will be perfect but I would recommend 500gb of space.
OK I see your point, but I think it should be fine. I was thinking of adding a flash drive for other stuff since they are cheap and give large storage.
