It can but not to a point of danger, burning, or any danger IF the PSU is a good quality one. However, if it's a bad brand, it can have possible problems.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/60888-psu-case-get-hot/#findComment-828319
im talking about the metal cover on the PSU itself... @Windspeed36 @Bluejay0
If the case is hot enough for you to force your hand hand when you touch it then there is a problem.
Listen if you care.
https://linustechtips.com/topic/60888-psu-case-get-hot/#findComment-828337
It gets warm (TX650 V2) but I don't think it will be hot enough to burn stuff. I would try to get a little space between the cable and the psu case in order to avoid getting the LEDs warm.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/60888-psu-case-get-hot/#findComment-832091
It would depend on the PSU, of course it will get abit warm as metal conducts heat. But the severity of the heat differs as to how well it cools itself.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/60888-psu-case-get-hot/#findComment-832273
