Hey guys!
Back in last winter I was already thinking about getting the S7 Edge after I've heard rumors of it being water proof, I was imagining how amazing it would be to take some pictures and videos from underwater.
But is the sealing in the S7 Edge waterproof when the water has chlorine (swimming pool) or salt (sea) in it?
Someone told me the S7 Edge's sealing will break down if you put it in salty sea water or in the pool (with chlorine)
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
https://linustechtips.com/topic/608841-s7-edge-underwater/
It's "Water resistant" Which means if you plan to take pictures really near to the surface like 2 feet under, you'll probably be fine. I wouldn't spend much time with it underwater though, especially in the ocean.
Current Build: Core i7 4790k @ 4.6, Asus Maximus VII Hero, Corsair Vengeance Pro 2400mhz 8gb (2x4gb), GTX 980ti, NZXT Kraken X61, Fractal Define R5  EVGA Supernova B2 850w, Some 300gb hard drive.
http://pcpartpicker.com/p/W7CNrH
https://linustechtips.com/topic/608841-s7-edge-underwater/#findComment-7878773
