Low CL-value vs High memory speed?
Solved by pyrojoe34,
Keep in mind timing values are directly related to Ram speed. Meaning that, for example, Ram at 1600mhz with a CL of 10 still has a higher latency than Ram at 3200mhz with a CL of 18. This is because timings are measured in number of clock cycles to perform an action, and since 3200mhz ram has twice as many cycles per second but the CL is less than double the latency, the CL 18 ram is still lower than the CL 10 Ram.
Having said that don't worry about RAM speeds, very few applications will even notice a difference and the cost is not worth the gains unless you have a very specific RAM based computation in mind for your computer.
