Surface Book OR Surface Pro 4?
Solved by vanished,
1 minute ago, AluminiumTech said:according to Linus's review, the card sticks out a bit. I probably will be able to fit everything onto 128GB but I'm just worrited about how long this will last since it's an expensive investment. I'm worried that over time the 128Gb will come close to completely filling up.
No doubt that with the OS, some programs, and some personal files you'll be using a good portion of it. I would look into alternatives that cost less. This type of machine is always getting more popular.
