Hey Guys!!
So I have built 2 custom PCs over the last year ( One for me and one for my girlfriend ) and I have to say, I have became increasingly addicted go just tearing my rig down and putting it back together.
Today I came to the realisation my PS4 console is just laying around, waiting for the next exclusive to tempt me into playing it again...
Thats why I have decided to transfer all the components of my ps4 into a small to mid sized PC case.
1. To make it more personal and unique.
2. To increase airflow into the console to lower sound and heat emitted from it.
I am not even sure if this is remotely possible but I would love to pull something like this off!
Please if you guys have any tips/advice/warnings for me I would greatly appreciate it!
Cheers!
https://linustechtips.com/topic/607438-ps4-nodded-into-pc-case/
Warning: Taking your computer apart and putting it back together is a good way to break it. But I'll admit, it IS fun.
Advice: Good luck getting a PS4 (custom PCB) into a standard computer case. Maybe do some googling on the subject.
i7 4790k | MSI Z97S SLI Krait Edition | G.Skill Ripjaws X 16 GB | Samsung 850 EVO 500 GB | 2x Seagate Barracuda 2TB | MSI GTX 970 Twin Frozr V | Fractal Design R4 | EVGA 650W
A gaming PC for your budget: $800 - $1000 - $1500 - $1800 - $2600 - $9001
Remember to quote people if you want them to see your reply!
https://linustechtips.com/topic/607438-ps4-nodded-into-pc-case/#findComment-7864173
2 minutes ago, AshleyR said:
I have a feeling I will need a lot of luck!
But yeah, I still working out how I would mount the PCB. Tried searching on Google for ps4 Nodded cases and damn vinyl skins kept popping up :,)
Your probably going to want to create a backplate to mount inside the PS4 case to house everything, but for a PSU suggestion I would say something like this is perfect for your situation depending on hardware:
http://www.hd-plex.com/HDPLEX-250W-Hi-Fi-DC-ATX-Power-Supply-16V-24V-Wide-Range-Voltage-Input.html
https://linustechtips.com/topic/607438-ps4-nodded-into-pc-case/#findComment-7864206
Someone did a build in an "already gutted when they got it" Xbox One and they had quite a few clearance issues. Getting the same amount of stuff into a PS4 would be really interesting. Unless maybe you're doing some sort of wicked mod to a laptop. In which case would likely have no issues and have plenty of room for "activities".
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
https://linustechtips.com/topic/607438-ps4-nodded-into-pc-case/#findComment-7864212
CPU: Intel Core i7 3770 @ 3.91 GHz RAM: G.Skill 4x4GB 2133Mhz DDR3 GPU: AMD HD 7970 3GB SSD: Samsung 840 Evo 500GB PSU: Corsair HX620W  Motherboard: Gigabyte Z68X-UD3H-B3 Case: Phanteks P400 Tempered Glass (Black) Monitor: Dell P2412H, Dell 2012H Keyboard: Razer BlackWidow Ultimate Classic Mouse: Logitech G203 Prodigy HDD: WD Black 3TB
https://linustechtips.com/topic/607438-ps4-nodded-into-pc-case/#findComment-7864215
38 minutes ago, AshleyR said:
Hey Guys!!
Cheers!
Console Pleb...
For real, I think this is a abomination and hope you plan on using it to start a fire so we can send a sacrifice to Gabe  N...
ALL HAIL GABE N!
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/607438-ps4-nodded-into-pc-case/#findComment-7864299
8 hours ago, JefferyD90 said:
Console Pleb...
ALL HAIL GABE N!
Why you feel the need to be a douche? Yes, I play console and PC... Stop being a dick...
https://linustechtips.com/topic/607438-ps4-nodded-into-pc-case/#findComment-7865835
2 hours ago, AshleyR said:
Huh pretty sure you didn't mean to quote me?
Anyways, I do pretty much the same I have an Xbox 360 and PS4, and want to get into PC gaming.
I think each has their advantages as well as disadvantages. But the argument against this current gen makes even more sense. The current consoles are basically neutered PCs. I mean they have APUs now. Which isn't a bad thing. But PCs have them too.
https://linustechtips.com/topic/607438-ps4-nodded-into-pc-case/#findComment-7866107
