Need help with fans in this case
Solved by WoodenMarker,
2 minutes ago, iM8Pizza said:Is an intel stock cooler a PWM fan(I'm still using the stock cooler, yeah...not good)
I doubt the front could fit something more than 120mm without modding (which I don't I'd do with this case...not really worth to mod this thing), and which one of those 2 you think more suitable for this scenario? It will not be fully blocked although with all 3 HDD installed, only half of it
Yes, it's pwm. PWM fans use 4pins as opposed to 2 or 3 pins.
If you're putting the drive below the other two and the top half of the fan isn't obstructed, go with the NF-S12A. I thought you that the drive was going to be above the current two earlier.
