Need help with Python
Go to solution Solved by ZEN,
To make it look more realistic, you could also randomize the sleep-time in between characters:
import timefrom random import randomtext = list("I have been waiting for you")std_slp = 0.2for char in text:    print(char, end="")    var = random()    time.sleep(std_slp*var)
This is in Python 3.3 as I don't know 2.7 so you would have to translate that.
(windows 7) (python 2.7.3)
(really new to python here)
I was wondering how I would make text appear as if it was typed without having to do this:
    import time
    time.sleep (0.05)
    print ('I'),
    time.sleep (0.05)
    print (' '),
    time.sleep (0.05)
    print ('h'),
    time.sleep (0.05)
    print ('a'),
    time.sleep (0.05)
    print ('v'),
    time.sleep (0.05)
    print ('e'),
    time.sleep (0.05)
    print (' '),
    time.sleep (0.05)
    print ('b'),
    time.sleep (0.05)
    print ('e'),
    time.sleep (0.05)
    print ('e'),
    time.sleep (0.05)
    print ('n'),
    time.sleep (0.05)
    print (' '),
    time.sleep (0.05)
    print ('w'),
    time.sleep (0.05)
    print ('a'),
    time.sleep (0.05)
    print ('i'),
    time.sleep (0.05)
    print ('t'),
    time.sleep (0.05)
    print ('i'),
    time.sleep (0.05)
    print ('n'),
    time.sleep (0.05)
    print ('g'),
    time.sleep (0.05)
    print (' '),
    time.sleep (0.05)
    print ('f'),
    time.sleep (0.05)
    print ('o'),
    time.sleep (0.05)
    print ('r'),
    time.sleep (0.05)
    print (' '),
    time.sleep (0.05)
    print ('y'),
    time.sleep (0.05)
    print ('o'),
    time.sleep (0.05)
    print ('u'),
    time.sleep (0.05)
    print ('.'),
https://linustechtips.com/topic/60698-need-help-with-python/
I did something like this a long time ago on a older pc. I'll go look and see if I can find the file
EDIT: I'm sorry I can't find the file, but what MikeD suggested should work
i9 25.6 GHz with NeuronThreading, 256gb 6000 MHz RAM, GTX 990 OC 3024MHz 12gb, Skeletal X99 motherboard, 1 Petabyte SSD, Fractal Design Humaniod R1 Case, Herbivore 10,000W PSU, Noctua NF16 LP Derma Cooler.
Probably the only Star Citizen player who is planning on a career in Journalism instead of piracy, mining, trading, exploration, military, station management, etc.
Generation 0: The first time you see this add 1 to the number and copy it into your sig. Consider it a social experiment.
https://linustechtips.com/topic/60698-need-help-with-python/#findComment-825808
You want to do something like this, assuming you want to print to a single line
import timeimport sysfor currentChar in "I have been waiting for you":    sys.stdout.write(currentChar)    time.sleep(.05)    sys.stdout.flush()
https://linustechtips.com/topic/60698-need-help-with-python/#findComment-826310
https://linustechtips.com/topic/60698-need-help-with-python/#findComment-828327
Can't seem to quote :/
Anyway, the issue with the way you are doing it @AllaboutPC is it will print 'I  h a v e  b e e n...' not 'I have been', I would go with the first way posted, since that will print it correctly
Intel 3570K - MSI GTX 660Ti 3GB OC Edition - 16GB Corsair LP RAM - ASRock Extreme4 Motherboard - Corsair HX850 - Adata Premier Pro SP900 120GB SSD with Windows 7 - Seagate Barracuda 1TD HDD - Seagate Barracuda 500GB HDD - Thermaltake Frio CPU Cooler - CM Storm Enforcer Case - Macbook Pro Early 2011 Laptop
https://linustechtips.com/topic/60698-need-help-with-python/#findComment-829757
