Problem with old HDD in external Case
9 hours ago, Captain_WD said:Hello
Could you post a screenshot of the way the drive is recognized in Disk Management and the brand and model of the drive?
The safest way would be to simply backing up the drive, reformatting the whole drive and then restoring the backup, but I understand it's quite the workload.There are ways to do that, but it involves some tweaking that I can't really recommend so you would have to look for that on the internet or wait for someone here to post it.
Captain_WD.
Well i borrowed another 2tb Drive from work and plugged them both into the pc. I copied everything from the old drive to the new one. Then i took the old one out and put it in the enclosure to format it on the laptop (just to make sure that it will work if i plug it in later). And now i am copying all files from the new drive back to the old drive. I will let it work trough the night since 1.5tb of data takes a while and we will see if it work.
I think its solved so i will mark it as solved ![]()
