gpu temps ok?
Solved by BrinkGG,
1 minute ago, DiGiTaL FaKiE said:at what point though do you think the temps will effect my game or my cpu? a have a fx 6300 oc to 4.1 ghz
The max temp for that card is 98c (from the GeForce website.) so as long as its below that it won't effect your game. But 83c is the "happy number" for nvidia cards where they all seem to cap out. And the 6300 is an okay cpu so if anything the CPU may already be bottlenecking in some games. Only way to tell is to look at benchmarks for the card with a different cpu listed.
