A couple days ago I was experiencing a problem with my PC. The problem was it would randomly shut down and instantly reboot. Today it would turn on, but I would get nothing on the screen, my monitor would just stay black. Anyone knows anything about this please tell me. :)
FYI I just got a ASUS Strix GTX 960 4GB about a week ago.
https://linustechtips.com/topic/603772-pc-will-not-boot/
Have you tried anything?
Any previous issues?
Can you get to the bios?
1 minute ago, LabRat said:
list specs
this too
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/603772-pc-will-not-boot/#findComment-7825885
We are going to need a lot more info than that. What have you tried? Have you changed anything recently? What are your specs?
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/603772-pc-will-not-boot/#findComment-7825890
4 minutes ago, HemiZzZz said:
I5 4690K
Kingston HyperX 8GB DDR3 1300MHZ RAM
Gigabyte GA-Z97X Gaming 3 Mobo
Seagate Barracude 1TB
Samsung 850 EVO 250GB
  Corsair Builder 750 Watt Non--Modular 80+ Bronze
Windows 7 Pro 64bit
BenQ XL2411Z
take the gpu out and see if it boots
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/603772-pc-will-not-boot/#findComment-7825919
I5 4690K
Windows 7 Pro 64bit
BenQ XL2411Z
I can't get into BIOS and I've tried resetting.
https://linustechtips.com/topic/603772-pc-will-not-boot/#findComment-7825922
Hi! I wrote a guide to troubleshoot POST problems.
Reply to Pc keeps shutting down, the boot looping randomly.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/603772-pc-will-not-boot/#findComment-7825929
2 minutes ago, HemiZzZz said:
I5 4690K
Windows 7 Pro 64bit
BenQ XL2411Z
your monitor cable is plugged into your 960, not the motherboard, right? and all power cables are firmly connected?
https://linustechtips.com/topic/603772-pc-will-not-boot/#findComment-7825932
1 minute ago, HemiZzZz said:
I've tested all of the connections and the monitor cable is plugged into the 960.
are your case fans spinning on startup? PSU fans? GPU fans?
is a speaker connected to your mobo (small one usually comes with mobo) and is it beeping on startup?
https://linustechtips.com/topic/603772-pc-will-not-boot/#findComment-7825939
My exhaust fan does not start spinning on startup. I do not have a speaker connected to my mobo.
https://linustechtips.com/topic/603772-pc-will-not-boot/#findComment-7825952
only the exhaust fan? the others spin on the GPU/CPU cooler/intakes?
https://linustechtips.com/topic/603772-pc-will-not-boot/#findComment-7825956
Those fans all spin of startup.
ok, then that exhaust fan probably is hooked up wrong and unrelated. Try plugging into your integrated graphics through the motherboard, do you get a post then?
https://linustechtips.com/topic/603772-pc-will-not-boot/#findComment-7825971
3 minutes ago, LabRat said:
check ( physically push the 20/24pin and the 4/8pin power connectors into the board. make sure they're firmly seated.
 the "hook the monitor to the back of the motherboard\" thing.............. do that.
what cpu cooler are you using?
I am using the stock Intel cooler.
https://linustechtips.com/topic/603772-pc-will-not-boot/#findComment-7826029
1 hour ago, HemiZzZz said:
Would it help getting a new MOBO? My reason is my CPU fan does not get power, my exhaust fan does not get power and I don't think my CPU is getting power.
check if all your PSU connectors are connected firmly on your MOBO.
it could be the problem of PSU as well.
https://linustechtips.com/topic/603772-pc-will-not-boot/#findComment-7828378
