From what i know cad is mainly cpu for the most part.
Magical Pineapples
https://linustechtips.com/topic/602892-question-about-cad/#findComment-7817181
6 minutes ago, Kaloex said:
Hi, this for a school project. I was wondering does an interior designer and space planner do 2d or 3d work and is it more GPU intensive or CPU intensive?
It kinda depends. If you want to show off something to a customer, you would want to use 3D. If you want to make plans for the contractor to build the thang, you need 2D.
I believe it is more CPU intensive, but it depends on the software. In my experience, Autodesk products are rather CPU heavy with some GPU acceleration, but something like Solidworks can take advantage of GPUs.
ASU
https://linustechtips.com/topic/602892-question-about-cad/#findComment-7817184
mostly CPU but some programs are GPU accelerated
in which case a GPU can be a huge improvement
https://linustechtips.com/topic/602892-question-about-cad/#findComment-7817186
