PC no longer powers on! Help!
Solved by Monkeypeas,
the orientation of the + and - on the power switch wont make any difference, but make sure they are all in the correct place, make sure everything is plugged in where it should be, the switch on the back of the psu is on, try a different psu cable, try a different wall socket, if nothing you do makes it power on, or atleast get some reaction out of it, then it points to a dead motherboard
this is all asuming it does nothing when you press the power switch, i'e no lights turn on, no fans spin etc.
