Will an APU + R7 250 (Dual Graphics) or a single R7 360 give me better performance?
Solved by DrMacintosh,
12 minutes ago, Sydlexic Deity said:My APU is an A8 7650K, and I'm looking at getting a graphics card to put in my system to up performance, but I'm not sure whether to go with the lower end 250 to get dual graphics, or the higher end 360 by itself.
Any advice would be appreciated
(I may overclock either gpu slightly, if that makes any difference)
500W PSU
2x4GB 1866 DDR3 (GSkill RipJaw)
ASRock AMD FM2+ FM2A68M-HD+
Going for the single R7 360 is what I would do. An APU offers very little performance compared to a dedicated GPU. Now, the R7 series isnt much good for anything other than like League of Legends and other basic titles, but its an ok card and I would recommend it over the APU and 250 combo.
