My dad want me to upgrade his old computer.  It has some sort of nvidia gpu (no name on it) and he wants a new faster one. It needs to be cheap and no other power needed only the power taken from the motherboard. I was looking at a Geforce 8800 GTS but I don't know if it needs any power directly from the PSU. If anyone has any suggestions I would like to know.
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
https://linustechtips.com/topic/599605-low-power-cheap-gpu/
Budget? Do you want to play games on it? non PCIe powered 950s? 750/750tis?
Looking at my signature are we now? Well too bad there's nothing here...
What? As I said, there seriously is nothing here :)
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782164
No planning to play games but he want it to be fast. And since we are not upgrading the CPU I want a better GPU.
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782170
CPU? if he's not going to play games then really any low end non-power GPU will do so yeah :P
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782177
GTX 750 Ti or GTX 950 that doesn't require a power plug (if those exist) is pretty much your best bet.
AMD unfortunately doesn't have anything as good in the low power consumption area. I believe their fastest is the R7 250.
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782180
As my budget is very low would a 8800 GTS be good just to make the pc faster?
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782183
You can find 260s without PCIe power IIRC.
anyhow, if not gaming anything besides an iGPU is useless
The GPU will NOT make the PC faster when the CPU, drive and potentially RAM are the issue
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782186
1 minute ago, M.Yurizaki said:
8800 GTS isn't low power though, it requires PEG power.
Oh... that is around my burget so are there any around that price what need no PCIe Power?
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782188
it won't make it faster
get an SSD instead
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782189
I am also upgrading ram from 1GB to 8GB.
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782191
If he has 1GB of RAM then even if you add a Titan X it will still be extremely slow. What CPU does he have?
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782193
intel core 2 duo
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782196
intel core 2 duo
He needs a new CPU + SSD + RAM. Upgrading the GPU won't do jack shit
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782197
But Still is there a cheap GPU around the price of a 8800 GTS with no PCIe Power? I know it wont do much but I would still like one.
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782202
You will literally be throwing money away. GPUs do NOT contribute to anything except games and HW acceleration
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782203
OP : Since U have limited budget (few bucks not few hundred), just buy another 1GB of RAM and 8600 GT.
CPU : Core i7 6950X @ 4.26 GHz + Hydronaut + TRVX + 2x Delta 38mm PWM
MB : Gigabyte X99 SOC (BIOS F23c)
RAM : 4x Patriot Viper Steel 4000MHz CL16 @ 3042MHz CL12.12.12.24 CR2T @1.48V.
GPU : Titan Xp Collector's Edition (Empire)
M.2/HDD : Samsung SM961 256GB (NVMe/OS) + + 3x HGST Ultrastar 7K6000 6TB
DAC : Motu M4 + Audio Technica ATH-A900Z
PSU: Seasonic X-760 || CASE : Fractal Meshify 2 XL || OS : Win 10 Pro x64
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782204
okay well thanks for the help. So I should just upgrade ram and CPU if possible.
PC Specs:
Case: Phanteks NV5
OS: Windows 11 Home
Laptop Specs:
Gigabyte Aorus 15G
RAM: 16gb DDR4
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782205
What he needs is a board + CPU + SSD + RAM upgrade. Go for a 2nd hand Nahalem/Sandy combo with 4GB DDR3 and possible a cheap 120GB SSD
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782209
Go for CPU if U have DX10 class GPU, go for GPU if U have DX9c class or older one.
RAM is a top pick for U tho (2GB RAM in total is required to do any multitasking these days).
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782212
Why should he care about DX9/10/11 when he isn't playing games? Any iGPU from intel is enough for his needs
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782215
DX9c = limited/no HW acceleration (not enough today)
DX10 = Hardware acceleration
DX11 = Hardware acceleration + good perf/power ratio
^It's a really simple (not ideal) explanation of what U need to get HW acceleration in YT/browsing.
Core 2 Duo CPU = LGA 775
775 integrated GPU's are BAD, since in most cases they can't HW accelerate anything modern browsers use.
Also, iGPU reserves some of RAM capacity for itself and with 1GB/2GB U need all the RAM U can get for normal tasks.
Also, I really don't see how U can sqeeze a modern Sandy/Haswell platform (CPU + MB + RAM) in "used 8800 GTS" budget.
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782217
He never said Haswell...He said Nahalem which is first gen core i3/5/7 and sandy which is second gen core i3/5/7 :P but you're correct, it would be impossible to get 4GBs of ram a core i3 CPU and motherboard for the price of a used 8800 GTS :P
https://linustechtips.com/topic/599605-low-power-cheap-gpu/#findComment-7782258
