as of January 2013, Corsair George has had a questionnaire about what peeps
need in an iTX case. LINKY. it kinda fits with the TTL saying there should be a
smaller baby bear case before the 350D, hum.
sample entries of what one needs in an iTX case:
  • Size - the smaller the better. I don't need a full GPU, I want a HTPC-style box
  • Size - I want it to be small, but I want a full size GPU and full size PSU in there
  • Air cooling - I want lots of fan options, top, sides, back, front.
  • Air cooling - I want it to perform well out of the box but we don't need to perforate every single panel.
  • "Sleek, Modern" Design - The BitFenix Prodiigy, NZXT Phantom Series, Corsair 600T and other cases with unique designs are my favorite.
  • "Refined, Aluminum" Design - Silverstone, Lian-Li, and Corsair Obsidian Series are more my speed.
  • Quiet - I want this thing whisper quiet.
  • Liquid Cooling - it'd be nice to be able to fit a 240mm radiator in this thing
  • HDD Capacity - I want to make a RAID or NAS box, so I want at least four 3.5" drive bays
  • HDD Capacity - I just plan on running an OS and a storage drive - two or three drive bays is fine as long as there's native SSD support.
  • Portability - handles and whatnot are really important to me. So is overall weight and durability.
  • Scent - I like all my computer products to be scratch and sniff. Please make this smell like Lilacs.
  • Other - posted in thread.
so corsair is making the jump to iTX and possibly for the obsidian line?
airdeano
https://linustechtips.com/topic/59958-corsair-itx-case-poll/
A few things I hope it is/has
Small (unlike the Prodigy)
Liquid cooling capable (like the Prodigy)
A window
Full ATX PSU
7990 capable
Something I hope it doesn't
Look like the Obsidian (I don't like the line for some reason)
https://linustechtips.com/topic/59958-corsair-itx-case-poll/#findComment-813797
i hear ya. for the family room show-off and piece of furniture look, just doesn't blow
my skirt up too high. iTX carbide style is sufficient for snatching the prodigy sales.
all the faux aluminum finishes and accents are dreamy, but not for direct pc users.
airdeano
https://linustechtips.com/topic/59958-corsair-itx-case-poll/#findComment-813814
A window
Full ATX PSU
7990 capable
Agree with everything. Does need a slick style though, similiar to the obsidian series.
Itx with a full GPU is the best way to do it.
https://linustechtips.com/topic/59958-corsair-itx-case-poll/#findComment-813829
Possibly a miniITX case built by customer feedback?
sounds great, my 350D is great, seeing something smaller would be cool
Probably coming out in it's own line if not the Obsidian Series.
Maybe a 350D on it's side with font panel and drive bays flipped on their side in a smaller form factor?
The Syndicate
https://linustechtips.com/topic/59958-corsair-itx-case-poll/#findComment-813844
Removable HDD cages (in single drives)
Rad support without cages in
180mm psu support (so we can use modular units
full dust filtering out of the box
Optional window
To keep costs down they could even sell the base line case and make HDD cages, windows, ect. extra's that you buy.
A clean front is a must though.
i5-3570k @ 4.4ghz (1.240v) || Asrock extreme 4 || CM Hyper 212 evo
Samsung 840 || WD blue 1tb || WD green 1tb || Powercolor 7870 xt @ (1200 mhz core : 1500 mhz mem)
Powered by a silverstone strider 500w psu in a NZXT 210.
https://linustechtips.com/topic/59958-corsair-itx-case-poll/#findComment-813951
Granted I haven't had any hands on time with the chassis, but I think EVGA almost got it right with the Hadron air. I like the slimline integrated PSU, contrary to popular opinion. The smaller you can get the build the better, IMO, and the PSU lends itself to that. I think if Corsair mimicked the Hadron Air but made it a tad wider to allow for cable management under the motherboard tray, put a CPU cut out in the tray, made the HDD cages and 5.25 bay removeable, and had radiator support in the top and front of the case it would be a home run.
https://linustechtips.com/topic/59958-corsair-itx-case-poll/#findComment-815880
A window
Full ATX PSU
7990 capable
Like the CM 130 Elite, I have been looking for a case with those exact specs (except maybe a window, builds this small don't often have the greatest curb appeal)
https://linustechtips.com/topic/59958-corsair-itx-case-poll/#findComment-828999
What I personally want is cube matx case from Corsair with the Obsidian styling. Something to compete with Lian Li cubes, but have much a better interior. I loved the style of my old Lian Li cube, but the internals of the PC-V354 is garbage. ZERO cable management and the PSU either pushes exhaust into a solid panel or blows hot air onto the graphics card...ugh.
Corsair, make a stylish mAXT cube, do it.
https://linustechtips.com/topic/59958-corsair-itx-case-poll/#findComment-829034
the original 600T had a lot of deisgn elements that are compatible for single card rigs that you don't want to show off ( no windows). Mitx boards won't be that visible when all hooked up so it would be nice to see a case that doesn't have to highlight the mobo with a window and focus on easy positive pressure cooling to combat dust and easy to build layout. oh and even though the Bitfenix Phenom is kinda meh, i think they are on to something with experimental hardrive mounts and the 750D is on the right track with that. Cages take too much space when you want as small case.
https://linustechtips.com/topic/59958-corsair-itx-case-poll/#findComment-840750
