Hi all,
I am thinking of selling my  i52500k(4.5ghz OC with mobo+ 16mb ram to my friend and upgrading to an 6700k setup. I currently have a gtx 970 card and I  game on 120hz screen with lightboost tweak. Would i76700k be a viable upgrade ? Would cost me almost half the price since I'm selling my old parts. Has anyone here made the jump from 2500k to 6700k ?
https://linustechtips.com/topic/597806-advice-on-upgrade/
I'd stick with a i5-6600K. Any performance boost you might get with an i7 is not worth the extra $100 it costs to get it. If you are going to spend that, some people recommend... and I forget the setup... one of the six core Haswell-E chips since it floats around the same price as the i7-6700K
https://linustechtips.com/topic/597806-advice-on-upgrade/#findComment-7763076
That would be a great upgrade. Here is a gaming comparison across multiple CPU generations:
The jump will be even greater going from an I5 to an I7.
[CPU: 4.7ghz I5 6600k] [MBAsus Z170 Pro G] [RAM: G.Skill 2400 16GB(2x8)]
[GPU: MSI Twin Frozr GTX 970] [PSU: XFX Pro 850W] [Cooler: Hyper 212 Evo]
[Storage: 500GB WD HDD / 128GB SanDisk SSD ] [Case: DeepCool Tessaract]
[Keyboard: AZIO MGK1] [Mouse: Logitech G303] [Monitor: 2 x Acer 23" 1080p IPS]
https://linustechtips.com/topic/597806-advice-on-upgrade/#findComment-7763090
