Don't burn in .wav format. You need to burn it in the .mp3 format.
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
https://linustechtips.com/topic/597216-what-is-wrong-with-my-cd/#findComment-7756353
31 minutes ago, hajsveen said:
Yesterday i burned a CD with my newest mixtape.  #olddays. But my cd player couldnt read it. Im pretty sure i know it was a .wav file.  Any suggestions?
Did you make sure the format is correct? It's not enough for it to be a .wav file, it has to specifically be 44.1kHz 16-bit stereo.
sudo chmod -R 000 /*
https://linustechtips.com/topic/597216-what-is-wrong-with-my-cd/#findComment-7756407
2 hours ago, tekgeek1205 said:
I dont have a pc with a burner.  So were using the shitty iMac.  So Windows /Microsoft support wont help
NEEVS
https://linustechtips.com/topic/597216-what-is-wrong-with-my-cd/#findComment-7756802
Test to make sue the disk can be read in another computer. If it can then you need to play with the burn settings. As easy as it would be you can't just drag and drop files onto the CD and burn them. Most CD players will read that as a data disk and spit it back out at you. Good luck!
The only thing we have to fear is... Stupidity...
https://linustechtips.com/topic/597216-what-is-wrong-with-my-cd/#findComment-7757282
I tried in a computer.  And it worked. But computers can read all sorts of media.  The thing is that a CD player can only read exact wav files.  Or in some cases/theese days. They can read mp3 too
NEEVS
https://linustechtips.com/topic/597216-what-is-wrong-with-my-cd/#findComment-7757397
What program did you use to burn the music onto the CD? Did you use iTunes? (Since you said you were using an iMac)
https://linustechtips.com/topic/597216-what-is-wrong-with-my-cd/#findComment-7757406
