6 minutes ago, dome_the_killer said:
I'm building my first computer. I have a part list on PCpartpicker http://pcpartpicker.com/p/wL3DCJ . Is there any thing wrong with it or should I change a part. I would love some feed back.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($194.89 @ OutletPC)
Motherboard: ASRock H110M-DGS Micro ATX LGA1151 Motherboard  ($49.99 @ Amazon)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory  ($26.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($45.89 @ OutletPC)
Case: Corsair 100R ATX Mid Tower Case  ($41.99 @ Micro Center)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($42.88 @ OutletPC)
Total: $402.63
Generated by PCPartPicker 2016-05-17 00:54 EDT-0400
(I've taken out peripherals)
But anyway. With the remaining 200$, you can try and snag yourself a second hand Gtx 970, which you can find out there if you look hard enough. You can also get windows for cheaper (either 7 or 8.1 versions) and invest that cash into the GPU.
Forget the SSD - you can add that later. Same thing for 16gb: add that later if you want. I changed the case because of preference, but I supposed you could get the one you like.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/597176-my-first-pc/#findComment-7755998
Or grab a brand new R9 380 and save himself from worrying if the 2nd hand 970 will have any hidden defect.
CPU: Intel Core i5-6600k 4.4GHz | Motherboard: Asus ROG STRIX Z270F Gaming | Cooler: Cryorig H7 | RAM: GSkill Ripjaws V 8GB 2x4 3200 MHz | GPU: MSI GTX 1070 Gaming X | PSU: Seasonic G-550w 80+ Gold Certified, Semi Modular | Storage: 250GB Samsung 850 EVO, 1TB Western Digital Caviar Blue | Case: NZXT S340 Elite (Black/Red) | Monitor: BenQ XL2411 144hz | Keyboard: Corsair STRAFE RGB Cherry MX Silent | Mouse: Corsair M65 Pro RGB
I'd like to make a Chemistry joke, but all the good ones ARGON. *nudgenudge *winkwink
https://linustechtips.com/topic/597176-my-first-pc/#findComment-7756057
Here you can buy an original Windows 10 key for about $30 US: http://www.kinguin.net/category/22175/windows-10-home-oem-key/ I found out about this from Paul's Hardware on Youtube. You could use the extra $60 to buy a better processor.
I also suggest you try and search for used GPUs. In a few weeks a ton of people are going to want to sell their GPUs to upgrade to the new Pascal and Polaris cards. so you can get a good deal on a better card, like a GTX 970 or an R9 390, even if it's used.
ZamoRIG 2.0:
Processor: AMD Ryzen 7 1700 @ 3.9GHz
Cooling: DeepCool Captain 240 RGB + 2x Corsair ML120 fans
Graphics Card: Gigabyte GTX 1070 G1 Gaming x2
Motherboard: Asrock X370 Gaming K4
RAM: 2x8GB DDR4 G Skill Ripjaws V Grey @ 2800MHz
SSDs: 2xPatriot Ignite M.2 240GB
HDD: WD Black 1TB + WD Green 2TB
 PSU: Corsair RM750
Case: Corsair Carbide 400C
ZamoRIG “Portable”:
Processor: AMD Ryzen 5 1600 @ 4GHz
Cooling: Corsair H80i
Motherboard: Gigabyte AB350N Gaming WiFi
RAM: 1x16GB DDR4 Corsair Vengance  @ 2400MHz
SSD: Patriot Ignite M.2 240GB
HDD: 2TB 2.5” Seagate HDD
PSU: Corsair TX650M
Case: Siverstone SG13
https://linustechtips.com/topic/597176-my-first-pc/#findComment-7756190
for OS, get it from kinguin/reddit at $20-30.
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  ($179.99 @ SuperBiiz)
Motherboard: MSI H110M Pro-VD Micro ATX LGA1151 Motherboard  ($49.99 @ Micro Center)
Storage: AMD Radeon R3 240GB 2.5" Solid State Drive  ($58.54 @ NCIX US)
Storage: Toshiba  1TB 3.5" 7200RPM Internal Hard Drive  ($42.89 @ OutletPC)
Video Card: XFX Radeon R9 380 4GB Double Dissipation Video Card  ($169.99 @ Newegg)
Case: Deepcool TESSERACT SW ATX Mid Tower Case  ($38.99 @ SuperBiiz)
Power Supply: XFX TS 550W 80+ Bronze Certified ATX Power Supply  ($53.99 @ Newegg)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer  ($13.89 @ OutletPC)
Monitor: Acer G227HQLbi 60Hz 21.5" Monitor  ($85.98 @ Newegg)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse  ($19.99 @ Newegg)
Total: $741.23
Generated by PCPartPicker 2016-05-17 03:30 EDT-0400
https://linustechtips.com/topic/597176-my-first-pc/#findComment-7756320
